Home > Camping, Caravanning and Holidays > Sankey - Camping Trailer Conversion |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
this is the first one i did
then on with the second one[ RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear |
9th May 2015 2:34pm |
then this one RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
9th May 2015 2:40pm |
Click image to enlarge not much more to do now RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear |
2nd Jun 2015 3:15pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
i have one here , i don't know what to do with it now . i would love to get a roofrack on to get the tent on it (any ideas)
sankey 3/4 ton trailer with 110 HC tub on it .. it came with the canvas top Click image to enlarge then i finally managed to find a 110 HC ifor williams top for it Click image to enlarge Click image to enlarge Click image to enlarge how do i get a roof rack on the trailer (fit tent on it ) |
5th Jul 2015 4:52pm |
make some cross bars and bolt them on then put the tent on them RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
5th Jul 2015 5:17pm |
ChrisLandyMan Member Since: 07 Jul 2015 Location: West Wales, Shropshire Posts: 5 |
Like this, the one i made a couple of years ago
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
7th Jul 2015 4:36pm |
i would love something like yours mate ..... wanna trade
7th Jul 2015 4:46pm |
haha... if you want to build something like it i can send more pics if you like... it just slides off and the trailer can be used
7th Jul 2015 4:57pm |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Now that's neat ..really like that idea
Terry |
7th Jul 2015 7:41pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
^^^ what he says!! Well,done, a neat and simple solution! What did you make the sides from?.. Cheers. Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
7th Jul 2015 8:01pm |
the trailer is just a narrow track sankey with steel box section on the top and the camping unit is made from the same box section as shown below and clad with sheet and ply roof which in hindsight should have been of the steel variety due to moisture buildup
7th Jul 2015 9:33pm |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 |
Can I ask what you used for door seals ChrisLandyman? When I built mine I made the doors out of box section steel clad in aluminium, and the 'doorframe' they close into is also box steel - so I have no return lip in the doorframe to mount a seal (a bit of an oversight when I built it, I should have used L-shaped steel as the doorframe). Can't quite make out how your seals work in the photos, so was wondering if you have a similar set up as me?
13th Jul 2015 9:52pm |
I had aluminium angle glued to the steel box to prevent galvanic corrosion and originally had rubber P seal that was stuck to the angle which sealed the doors 1992 Defender 90 200tdi Hardtop (rebuilding)
1997 Discovery 300tdi 2003 Defender 110 Td5 Double Cab |
13th Jul 2015 9:56pm |
Thanks, sounds like a good solution!
13th Jul 2015 10:08pm |
