Home > Camping, Caravanning and Holidays > Sankey - Camping Trailer Conversion
Hectic haggis
Scotland 2015 Defender 110 Puma 2.2 SW Corris Grey
Ok, so I've just bought a Sankey widetrack (mark 2 I think Confused ) and collect it on Sunday.
My plan is to use it for the usual tip runs etc, but also would like to be able to press a button and change it into a camping trailer...
.... Whistle
...Ok, so not at the press of a button, but I'd like the top to be light enough to lift on and off reasonably easily.
In my head, I'm thinking these trailers were designed to run in the tracks of the towing defender, so they must be pretty much the same width - right? Rolling Eyes
So, does anyone know if its as simples as to stick the side panels and roof of a Series 3 or defender onto the sankey trailer tub (albeit having to trim the length)?
I've had a look ont interweb and not seeing this done very much, which makes me think its not that easy.
Any help or advice welcome (as well as the anticipated slagging for being so naive Wink )
Post #421970 8th May 2015 10:01am
davew
Like this you mean ?
Not mine but pretty much what you are suggesting. I like the use of a kind of dummy rear cross member although it could do with some shackle extensions to match the Defender's lift.
The widetrack is indeed the same track as a Defender and I would think that a 90 back body would pretty much fit fairly easily. The only difficult bit might be panelling in the front although if you leave the bulkhead in place and make a small compartment at the front you will be able to fit as standard soft top or Ifor Williams top. Maybe fit some small batteries in the front compartment then. http://www.yorkshireoffroadclub.net/
Post #421975 8th May 2015 10:18am
Hectic haggis
mmm not really, what I'm thinking is to keep the sankey "as is" but lift on and off the (modified) top part of a hardtop.
Ie: by day its a mild mannered standard Sankey, but by night its a mild mannered Sankey with the back & top of a defender (or series) bolted to it...
Kind of like "the blackbird" used by Loughborough LRC, but only the top bit being landrover and the bottom bit being sankey
(I dont seem able to attach the photo for some reason Embarassed )
:http://www.loughboroughlrc.co.uk/userimages/DSC_8071.JPG
Post #421978 8th May 2015 10:27am
davew
Sorry, with you now.
Using the Sankey tub itself is more difficult because it's actually wider than a 90 back body at the top by a few inches because it has vertical sides instead of being "waisted" like the Defender. You'd have to either widen the top to fit or add some sort of filler panel.
I hadn't realised this myself until I decided to try and stick a Defender soft top on mine, at which point it suddenly made sense. It MIGHT be the same width as a High Cap though... not sure. http://www.yorkshireoffroadclub.net/
Post #421979 8th May 2015 10:31am
Hectic haggis
Cheers Dave
I had looked online for dimensions and seemed to suggest they were compatible, but I reckoon I'll wait til I have the Sankey on Sunday and measure it a and take stock of options.
What did you do in the end ?
Post #421987 8th May 2015 10:58am
landy andy
Made mine with a lift off top.
Andy
Post #422003 8th May 2015 12:02pm
shaggydog
There is the pic chap Thumbs Up
I think it may be difficult to do otherwise they would have done that rather than just stick a 110 rear on it.
Having said that, there is nothing stopping you making a frame for the defender top to sit on and then drop into some box section in the tub which locks it down. But you may loose some space on the inside.
Only issue I can see is that a roof and sides is deceptively heavy. On my own I just about managed to lift the roof and rear panels (admittedly with the windscreen on) of my 110 when I was doing my rebuild but with 2-3 of you around it should make it easier.
Interesting project ether way Very Happy
Make sure you keep us all posted with lots of pics Thumbs Up [/quote] Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #422011 8th May 2015 12:26pm
^^^ It's surprising just how peculiar that looks with no towing vehicle attached - almost as though someone has cropped the front out of the picture! Shocked
Bet it looks good behind the matching tug though!
Post #422040 8th May 2015 2:18pm
Hectic haggis
Andy
That's looks really professional Andy. Thumbs Up Not sure I'd have the skills to replicate. What did you use for the top?
Post #422063 8th May 2015 4:00pm
RLD
looking good there Thumbs Up RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #422064 8th May 2015 4:03pm
Hectic haggis
[/quote]
Yeah - I'm quickly starting to doubt myself on this "little project". It could easily turn out like a load of arse. I'm going to hold fire until I collect the Sankey and have a good think about what's realistic for my ability, available time and budget. (Maybe just cover the top with cling-film is as about as good as I'll get!)
Will keep you posted either way...
Post #422065 8th May 2015 4:04pm
RLD
Have a look on the D3/4 site plenty of SANKEY trailers on the site just get a photo in your head thats all you need then do it RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #422066 8th May 2015 4:11pm
VeeTee
Netherlands
You could use the roof of a Defender or Series, like mine here, but you'll have to adapt the width of the roof, the trailer tub width is less than the roof width. I am currently upgrading this one, it is a M416A1 trailer:
 Cheers, Vincent
MySite
Post #422067 8th May 2015 4:15pm
Hectic haggis
I like that Vincent and have read about a similar build.
In my minds eye I'm thinking I want more height to allow for inclusion of pull-out kitchen and a canopy etc in the future.
Also, mine is a widetrack so I guess the tub will be wider than yours as it sits over the wheels not between them?
Out of interest, can you recall how much did you need to remove from the roof?
Doug
Post #422069 8th May 2015 4:25pm
VeeTee
Netherlands
I just took the measurements, approx. 13 cm was cut out in the middle section (I bought it this way).
I now changed the roof hinges for stronger welded on ones, and uprated the gas struts so the roof is lifted easily even with roof rack and lugage on it. The roof was primered last week, and will be painted white soon. I ordered Epsom Green paint made to colour for the body, I think I will paint the chassis and wheel spats black. Smile
 Cheers, Vincent
MySite
Post #422075 8th May 2015 5:13pm
