Home > Puma (Tdci) > 90 Rear Seats |
no problems , apart from they bl@@dy heavy
torx bolts inside , two 13mm nuts under arch plastic screw rivet thing hold plastic covers on over seat mech each end , undo centre screw pull out plastic rivet , torx bolt are underneath the cover I always take one out when going on holiday to free up the space |
29th May 2014 1:14pm |
RlpV8 Member Since: 31 May 2014 Location: Northampton Posts: 25 |
I just removed one of my rear seats after having worked round the ruddy things doing 2,000 miles around Scotland in the last couple of weeks. What a nuisance the seats are. Removal was easy all Torks with the exeption of two studs that go through the floor. Put all the bolts back in to seal the holes. You'll need to M8 bolts to fill the holes where the studs went. Can't believe the space I now have.Second one is coming out tomorrow!
31st May 2014 7:03pm |
TheDuke Member Since: 11 Sep 2013 Location: Lancashire Posts: 6 |
Thanks chaps. Took one of them out yesterday prior to a run down to Cornwall. No problem coming out and yes, the space it frees up is great. It won't be going back any time soon.
31st May 2014 7:12pm |
Dfrs Member Since: 03 Oct 2013 Location: Ireland Posts: 91 |
Hi , will any one be selling one of their seats that they have removed , I am looking to buy one ?
Denis |
31st May 2014 10:19pm |
MrOl Member Since: 21 May 2015 Location: East Anglia Posts: 41 |
Need to buy a torx set to remove these - does anyone know what size torx head is needed for these bolts?
4th Jul 2015 6:22am |
t40 torx 3/8 drive and 6 inch extension makes it easier
+ 2x 13mm nuts under arch I made a storage shelf to go in place of the seat when I take my seat out |
4th Jul 2015 6:30am |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Does anyone know the correct torque(s) for re-fitting the fasteners? (or where to find that info)
4th Jul 2015 11:06am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
I'm looking to do the same with my 2 rear seats.
Is this something you can do on your own or do you need one person on the spanner end in the wheel arch and one person in the cabin? (I'm good, but I can't be inside and outside the car at once! ) 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
28th Jul 2015 8:32pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 |
Won't it be nice if they were quick release?
28th Jul 2015 8:46pm |
