Home > Maintenance & Modifications > 4 Wheel Tracking Help
Defender-Stu
Hi Guys, anyone know somone who is very good at 4 wheel tracking in the Weston Super Mare down to Taunton Areas i want mine checked? i have been told its 5mm out on the osf, so was going to get under it and adjust that side by one turn on the ball joint?
Thanks For your help
Stu
Post #435229 2nd Jul 2015 7:25am
Retroanaconda
I would like to meet the man who could do 4-wheel tracking on a Land Rover!
Post #435416 2nd Jul 2015 8:57pm
DSC-off
Sorry I can't help with a recommendation in your area, but I don't think you need anything as technical and specialised as 4 wheel tracking. 4 wheel tracking would be necessary for fully independent suspension, adjustable at each corner.
With beam axles on a defender, there's nothing to adjust on the rear axle.
At the front there's only the track rod and drag link.
Any decent garage should be able to set it up for you, preferably one that understands ancient technology. Very Happy
HTH.
Post #435419 2nd Jul 2015 9:09pm
Dave_S
Completely agree - I've heard a few garages rip off people by claiming to do 4 wheel tracking and alignment on a Landy Evil or Very Mad
Post #435431 2nd Jul 2015 9:54pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I went to a Defender/Land Rover specialist close to me, they were great, very good people to deal with, they said they'd heard of other garages saying they could do 4 wheel tracking on a Defender - they obviously can't - if they said they could then they're taking the preverbal. The only wheels that can be tracked on a Defender is the front 2.
Once done properly it made a huge difference.
Post #435439 2nd Jul 2015 11:08pm
munch90
technically you can check the 4 wheel tracking
example would be if you where unable to get steering wheel centred right
most tracking places if not all , will lock steering in straight ahead postion then track front wheels , but if rear axle is out of line then to compensate for that you would need to steer opposite way to counteract that hence putting steering wheel out of line , but front wheel tracking would still be right
agree that you couldn't adjust each rear wheel , but if gauges say one rear wheel out = axle bent , both rears out =bent chassis or just bad chassis as defenders have high build tolenrences
you wouldn't find a garage able to adjust it because as said there is no adjustment , but its still handy to (or frightening ) to know , how far out it is
it can be done by cutting brackets , making spacers , shortening/lengthening arms etc etc but its a lot of work and time
Post #435467 3rd Jul 2015 7:29am
