Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Thanks RoddyK05, the list of mods (aspirations) is growing fast
Which anti-corrosion paste did you use on the stainless steel bolts? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Hi there, I used the one that came with the SS set, Berner Anti-Seize paste.
You have me thinking about how much paste I should of used on each bolt, mmmm. I smeared a fine film down the length of each bolt. Any thoughts/suggestions?
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
today got my windscreen washer working again (note to self check non return valve BEFORE removing dash board top)
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Sorted my wiring issue which kept blowing my spotlight loom fuse.
Turns out when I moved it I had reversed 2 plugs so when triggered it was sending mains voltage to earth ![]() Tracked down a rattle in the back which was being caused by a rattly step and then thought about cleaning it but decided to water the garden and do some weeding instead! ![]() I have got photos to stick up in my rolling restoration thread of putting in a red bison loom but as my laptop screen is dead on one side it makes it very difficult! ![]() Self confessed mileage hunter ![]() |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
Been a busy boy today fitting:
Washer bottle cap Upper waist seals front door rubber seals back mudflaps with stainless bolts led side indicactors from leeds and stainless guards to protect them 2004 TD5 Defender 90 xs station wagon |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Yesterday: after 11 years and a quarter of a million miles it was the first time the door catch tore the rear pocket of my jeans.
Spent the afternoon at work pulling my t-shirt down over the hole... ![]() Green Goddess - 1998 Defender 110 300tdi |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Had a fun day towing my boat, maybe even more fun than sailing it:
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Thats a bloody big grey fender you have for it mate!
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 ![]() ![]() |
finally got my led spots set with main beam
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Not today but all day yesterday, took a 12 hour round trip to Wales to look at something special
![]() ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 388 ![]() ![]() ![]() |
Finally fitted a blue sea fuse box next to the fuses under the seat, and linked to the battery box with flexible conduit. Will be wiring up another day. Additional electrical mods to follow.
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Removed the window blocks from the truck and added silicone sealant to the gaskets. Also added silicone sealant to the windscreen seal, I essentially added a bead of silicone to the sponge on the outside.
Gave it 30mins and then out with the hose, still a few leaks, but played with the vent flap and eventually no leaks (today). So I think I have cured the window block leaks, and mitigated or cured the windscreen seal leak. I need to remove the vent flaps and fit new seals to the flaps, that way I will have mitigated another leak point. Cheers Andy |
