![]() | Home > Td5 > Fuel pump sounds? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
Turn the key to position II, then this sounds start...
Continue for about 30Sec then will stop...Is this normal? I'm checking if my fuel pump start to fail! ![]() https://youtu.be/VTAcocgYmMI |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Probably the pump (in tank) priming the system, although I think there it a non-return valve to stop fuel draining back to the tank which should avoid this. This was the case on a TD5, not sure about later Pumas. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Is there not a pressure switch that cuts in to prevent it from continually running and overpressurising once primed unless the engine is started? If you go through life with your head in the sand....all people will see is an ar5e!!
My lost of power "uphill" might be cause by a bad fuel pump, will cut a hole in the back penal, take it out for a look!
replace or clean as it need! I would get a new pump for spare, get a VDO one! |
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 ![]() ![]() |
Have this sound after fitting new fuelfilter, disapeared after 5-6 startups. Are you sure you don't have any air in the system? Just some thought's. ![]() -09 Jaguar xk4,2 Portfolio |
If anyone is interested or just plain curious I thought I'd post this link back up to show that getting to the pump from above on a 110 Td5 isn't too bad.
http://www.defender2.net/forum/topic28189.html It certainly makes things easier for the future. |
my TD5 have this sound everytime ture the ket to II for about 30Sec! seems like the sounds gone after engine started! |
I'm going to do this soon, I have a bit worry cutting those fuel hoses, since I'm not going to cut with the tank lower! |
The fuel pipes are a good 50cm below the tin of the floor, you would have to be very rough to cut the pipes and wires when cutting a 2mm piece of aluminium sheet.
