Home > Td5 > Fuel pump sounds?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Fuel pump sounds?
Turn the key to position II, then this sounds start...
Continue for about 30Sec then will stop...Is this normal?
I'm checking if my fuel pump start to fail! Mr. Green
https://youtu.be/VTAcocgYmMI
Post #428485 4th Jun 2015 3:10am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Probably the pump (in tank) priming the system, although I think there it a non-return valve to stop fuel draining back to the tank which should avoid this. This was the case on a TD5, not sure about later Pumas. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #428550 4th Jun 2015 10:09am
K9F
Is there not a pressure switch that cuts in to prevent it from continually running and overpressurising once primed unless the engine is started? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #428553 4th Jun 2015 10:16am
alexatnd
My question about fuel pump sounds is ...how loud is normal?
On my 1999 TD5 110 from the drivers seat you can just her the pump and no more. On my 2004 TD5 110 from the drivers seat, its damn loud.
Am heading for France in the 1999 110 an am wondering if I should take a spare pump with me Smile
More to the point, given that the fuel pump is above the fuel tank, if I did need to change the pump, which necessitates dropping the fuel tank, is there anything else worthwhile changing while the tank is out?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #429420 8th Jun 2015 8:33am
RF3777
My lost of power "uphill" might be cause by a bad fuel pump, will cut a hole in the back penal, take it out for a look!
replace or clean as it need!
I would get a new pump for spare, get a VDO one!
Post #429422 8th Jun 2015 8:37am
takoon
Norway
Re: Fuel pump sounds?
Have this sound after fitting new fuelfilter, disapeared after 5-6 startups. Are you sure you don't have any air in the system?
Just some thought's. Thumbs Up -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio
Post #429546 8th Jun 2015 4:41pm
JWL
If anyone is interested or just plain curious I thought I'd post this link back up to show that getting to the pump from above on a 110 Td5 isn't too bad.
http://www.defender2.net/forum/topic28189.html
It certainly makes things easier for the future.
Post #429586 8th Jun 2015 7:27pm
RF3777
my TD5 have this sound everytime ture the ket to II for about 30Sec!
seems like the sounds gone after engine started!
Post #429652 9th Jun 2015 3:47am
RF3777
I'm going to do this soon, I have a bit worry cutting those fuel hoses, since I'm not going to cut with the tank lower!
Post #429653 9th Jun 2015 3:49am
JWL
The fuel pipes are a good 50cm below the tin of the floor, you would have to be very rough to cut the pipes and wires when cutting a 2mm piece of aluminium sheet.
Post #429666 9th Jun 2015 6:41am
