![]() | Home > Td5 > Valeo or Genuine clutch and flywheel? |
Ronny S Member Since: 20 Aug 2007 Location: Valle i Setesdal Posts: 12 ![]() ![]() ![]() |
Do you also change the flywheel bolts?
Think they should be about 40Nm + 90 degrees. Hard to pull the last 90 ... Ronny S |
I suppose that 177K miles I must resign myself to changing the original clutch.............. one day
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
My clutch has started slipping at 75k miles, the spiggot bush is squealing in reverse, and there is a rattly sound when idling, perhaps this is what is known at chattering?
Anyway, I need it replaced ASAP as I'm off on holiday in it in a months time. The local independent has quoted me around £1300 to do the job, including the DMF (oem kit), I just wanted to know if this sounds about the going rate? I'm happy to pay it as I don't have the time to do it myself at the moment, but I was a bit surprised it was this much given the price of the parts. It only took a few hours to it on my old lightweight! |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
That seems a lot. Think it cost me ~ £800 to h ave mine done on Gertie. Still got the receipt so I'll check tonight
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Thanks Alex. Since booking it in, the car has decided to stop slipping its clutch now - no matter how hard I tried at the weekend. I'm now wondering if oil leaked onto the clutch plate from the crankshaft seal?
I've emailed the garage anyway and they'll take a look when they do the DMF. It will be worth it just for the piece of mind - I don't want it failing on me when expeditioning next month! (even if its only in the dizzy heights of the Welsh mountains ![]() |
