Home > Maintenance & Modifications > Front swivel seals (i think) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
just make sure you wipe them before next years MOT! DEFENDER 90 TDCI XS,
4th Jun 2015 4:57pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
It's a bit off work but you can easily do it yourself.
Take the whole hub assy off: Click image to enlarge And then you can easily change the seal. I had to do a little more: Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
5th Jun 2015 7:11am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I covered it recently in my rolling restoration thread here http://www.defender2.net/forum/topic28138-150.html
Please only use it as a "what it all looks like rough idea" rather than a definitive "how too guide" as yours being a later model will be subtlety different. (and its not meant to be a how to guide just a how I did it documentary) As you are only doing the seal I would just take the brake caliper off and then unbolt the whole assembly from the axle and change the seal and then re fit, don't bother with any of the other bits if they don't need doing. - be careful it is very heavy! What is the condition of your swivel balls? (if you don't mind me asking ) If they need replacing now it the time to do it in which case get the full kit and go in the standard way stripping the whole lot off that end of the axle will be much better. I would highly recommend using new bolts when doing so and new gasket. Which will be available from your main dealer for less than £10 -Only use genuine here Stick some photos up when you do it I was quoted £195 for main dealer to do my swivel rebuild using parts I supplied they said was about 1.8 hours labor if that helps Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
5th Jun 2015 11:44am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2647 |
If the balls are in good nick and it is just the seal that is leaking, then there is a 'bodge' way of doing it.
Remove the old retainer plate and hang it back over the axle tube, then take the old seal out and cut it off. The spring can then be removed from the new seal and carefully seperated from itself to unloop it, then you cut the new seal squarely and slide it over the narrow part of the swivel ball. It then needs to be glued back together accurately using a decent glue. Then loop the spring round the ball and re-attach it to itself, and refit to the seal. Re-fit using a new retainer plate gasket (which will also have to be cut), ensuring that the bit you cut and glued goes at the top of the swivel ball. If you are taking the balls off the axle anyway then it's worth doing it properly, but the above can save a lot of work if so inclined. |
5th Jun 2015 1:07pm |
