Home > Maintenance & Modifications > Extended mirrors for towing
Page 3 of 4 <1234>
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
yes, can see both sides and know what gap i can get it through or reverse it in to. They only thing i can't see is the leg of the engine in the middle at the back - but you wont see that even with 6ft long extensions !
Post #42610 13th Oct 2010 5:03pm
Laurie
Then you're legal but I still can't understand your original statement in this thread.
nicks wrote:
If you feel you need extended mirror arms, then you shouldn't be towing.
Post #42619 13th Oct 2010 6:07pm
Lorryman100
Towing mirrors
As I tow a 26ft caravan I checked with the milenco website and found this:
Towing Mirrors – The Law
The Law in the United Kingdom specifies, you must be able to see clearly down both sides of the caravan/trailer, and see 4 meters either side of the caravan/trailer at a distance of 20 meters behind the rear of the caravan/trailer.
This in reality means, if your caravan/trailer is wider than the rear of your tow vehicle, you must fit towing mirrors to comply with the law. You can be fined up to £1000 and get 3 point on your licence for towing blind. (At exhibitions, we have met many caravanners that had received 3 points and £60 fixed penalty notices.)
On tow vehicles conforming to directive 2003/97 EC or sold after January 2007, the towing mirrors may project 25cms further than the widest part of the caravan. On tow vehicles pre dating this directive, the mirrors may project 20 cms further than the widest part of the caravan.
Since 12th of December 2005 it is a legal requirement that you have type approved (e-marked) mirrors on both sides of the tow vehicle.
I use Magnum xl mirrors which are ideal for the defender and cost less than £20 a pair Very Happy
Post #42625 13th Oct 2010 7:05pm
Quote:
Taken from the direct.gov.uk website
These mirrors must be E-marked (mirrors with this mark meet EU requirements).
Does this means that only extended mirrors have to be E-marked, or that mirrors used when towing have to be E-marked, or all mirrors have to be E-marked?
I am guessing that only the clip-on temporary extended mirrors need E-marks.
I don't think my standard (Britax?) mirrors are marked at all.
Post #42638 13th Oct 2010 10:37pm
WarPig
Re: Towing mirrors
Where did you get your Magnums from please, Im struggling to find them online
Post #42639 13th Oct 2010 10:59pm
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Hi,
I tow a 8.25m caravan with my Defender 110, I fitted some Britpart extension arms with large Spafax unbreakable mirros from Paddocks. The near side one is convex as I've a Hard Top and have a blind spot anyway (no side windows). I can see round my rig when towing and like this setup even when not towing, as I've great visability.
Post #42640 13th Oct 2010 11:50pm
jst
Didnt the law change recently regarding what you now have to be able to see behind what ever it is you are towing? when i say recently i mean 2 years ago. For example towing a box bodied Ifor at max width meant we needed extended mirrors on the works D3s. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #42641 14th Oct 2010 5:39am
Laurie
--defender-- wrote:
Hi,
I tow a 27" caravan with my Defender 110, I fitted some Britpart extension arms with large Spafax unbreakable mirros from Paddocks. The near side one is convex as I've a Hard Top and have a blind spot anyway (no side windows). I can see round my rig when towing and like this setup even when not towing, as I've great visability.
Unfortunately, driving with extended mirrors when you're not towing is also an offence Neutral
PS 27 inches is not very big. Do you sleep standing up? Whistle
Post #42651 14th Oct 2010 10:17am
Eduardo
Allways you learn something here
In Chile the regulation in not so strict about the mirrors/towing, but better be in the safe side.
I will see also SMAT Nord mirrors, according other forums are a good alternative an fits on Defenders.
Cheers Eduardo
Post #42657 14th Oct 2010 12:22pm
Lorryman100
WarPig,
They are called smat magnum mirrors and pennine leisure stock them. Drop them an email to confirm size as smat has changed their mirror names! Basically they work on a scissor action to adjust to the size of your mirror and are held on by lugs on the front and strong rubber straps on the back. Was going down the motorway in the summer and was accidently doing 70mph Rolling Eyes whilst towing and they where rock steady, plus if you lose one they are only a tenner Smile
http://www.plsgroup.co.uk/index.php?_a=viewProd&productId=443
Post #42662 14th Oct 2010 2:23pm
Eduardo
Here also at 9.95 GBP each!
http://www.mmleisure.co.uk/cgi-bin/sitewise.pl?act=det&p=1095
If I going to this solution probably I will buy in USA (lot cheaper for me)
I have time to wait if Laurie or Glyn can help me in my search
Cheers Eduardo
Post #42665 14th Oct 2010 3:54pm
WarPig
Thanks Lorryman100 & Eduardo, Ill buy some for next season Very Happy
Post #42666 14th Oct 2010 5:35pm
Lorryman100
Quote:
Laurie
Rolling with laughter Rolling with laughter Rolling with laughter
I thought size doesnt matter its what you can do with it.........and if mine was 27 inches (not the caravan), I'd be on here bragging too.......
Post #42704 15th Oct 2010 2:55pm
--defender--
I've converted the misleading imperial units to metric units to keep things on-topic. Embarassed
A 110HT is classed as a commecial vehicle, my mirrors are not as obtrusive as many other vans and get the job done. Just trying to be helpful...
Post #42705 15th Oct 2010 3:50pm
gav///m5
2005 Defender 110 Td5 XS CSW Cairns Blue
how much longer are the Wolf type arms than standard ?
Post #43043 19th Oct 2010 2:06pm
Page 3 of 4 <1234>
