![]() | Home > Maintenance & Modifications > Extended mirrors for towing |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 ![]() ![]() ![]() |
My Wolf arms are quotted at being 290mm, I've just measured them, from the centers of the mouting pins at either end measures 265mm. The final width depends on which mirrors you fit and how you orientate them (landscap/portrait). With large heads in portrait mine measure 360mm from the door hinge to the edge of the mirror. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Thanks to all,
Finally I got a pair of new arms from e-bay UK for 40 GBP that as I saw in the market is a fair price. Grockle, be prepared! Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Lorry,
Probably I will receive it next week. So, no fitted yet. As soon as I finish to install it I will post some photos. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
casher Member Since: 17 Sep 2010 Location: Glos Posts: 58 ![]() ![]() ![]() |
have you got any photos yet, im interested in them too, but im worried about hitting things with the extra length? just wondering how you found them? |
casher
I bougth it through e-bay, Not arrive yet to here (a long trip from UK to Chile) here you can see how look like (not installed but can give you an idea about the length) http://www.rimmerbros.co.uk/Item--i-RRC8443P Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
If the picture is correct, this is one of the alternative (pattern?) ones.
These mount with the arm at 90° and 45°. The Wolf arms mount at 85° and 30° |
Yep, finally I bought the alternative ones (Britpart) and I hope that will fit and last at least some years.
My intention is use only for towing and back again to the originals at the end of the camping season. I didint realize that had a different open angles, but we will see. Cheers, Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I've got Wolf ones on mine.
The others will give a wider rear view, possibly better. I've got a set to try sometime. |
