![]() | Home > Maintenance & Modifications > J.W. Speaker vs. Nolden LED headlamp test |
Late answer... but yes I changed the JWS with the Nolden... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
A bit of a thread resurrection....
Sofar we had done the EVO/Nolden comparison test in static underground garage conditions. Which were pretty good conditions to compare I think, and result was basically that with some slight differences in light spread and light color, you could call the result a par... Now, while I know how my Speaker EVO perform on the road in the dark, I did never experience the same for the Nolden, until last friday that is... I had the pleasure on friday to drive back in the Hunter of my friend kitoper from Entreq in Uhldingen-M�hlhofen all the way back to Geneva. A 5 hour drive, with quite a few long tunnels to pass. Kitoper has the Nolden on his Hunter, and for the first time I could see from the passenger seat how they perform in all those tunnels. Very, very good I must say. Kitoper's Nolden are well aligned as to height, and there is no real hotspot visible then (which is something I feared they would), the overall light emission forward is a very regular pattern, strong, and the light beam to both sides of the road is quite strong and far reaching also. So overall a very, very good lamp, easily at par with the performance of my EVO. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 ![]() ![]() |
thanks Eric - as my Defender mentor
he he he Eric............
![]() ![]() IID Pro MV License |
No, that is not what I am saying at all. If you reread the comparison thread from the start again, you will see that we said that in the underground garage conditions we saw a more pronounced hotspot with the Nolden than with the Speaker EVO. The Speaker EVO seemed to have a more equally distributed light pattern there. In all honesty, in various pictures posted by some on here later, you often can also see that pronounced hotspot with the Nolden. And kitoper in the beginning had such hotspot with his Nolden. But, that seems largely a matter of not perfectly levelling them. Kitoper later has been able to raise his Nolden beam up some without blinding oncoming traffic, and when we were driving last friday, I did not see any hotspot anymore. As said the lightbeam was strong and wide. Actually very similar to the Speaker EVO which I have, so I cannot do better than still call them a par. ![]() I don't know about the EVO2, they seem to be a leap ahead again as to light production. Don't think I will find out quickly, because my EVO are very good and LED are supposed to last forever, mine do neither rust, nor fog up ever, and I much prefer the smaller parking light LED in my EVO than the half circle parking light of the EVO2. dgardel, as far as your grinning is concerned... In this whole discussion about Speaker vs. Nolden, I have tried to give a honest comparison based on what you really see, and I have not let myself guide, or better misguide, by silly non standardized apples and pears lumen number discussions. And certainly not by throwing into this same comparison experiences of the older first generation Speaker (which probably indeed had its flaws) with the newer Nolden as some on here have been keen to do. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 25th May 2015 10:34am. Edited 1 time in total |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3791 ![]() ![]() ![]() |
Eric, No worries, You've been pretty honest,...can't do more than that.
Pickles. |
Eric, You've been pretty honest
I think that Nolden and JWS are very closer in performance and people can choose what likes without fear of a wrong purchase. Eric, your tests and well done and honest! ![]() ![]() ![]() IID Pro MV License |
Daniele ever the diplomat.......
![]() I have had both JWS and Nolden lights as have several others, output on both far exceed OEM and for that reason alone either is an excellent upgrade. A few lumens/hotspots aside in comparison nobody should fret and I don't give a toss as mentioned both are fantastic. The quality of any headlight stretches far beyond light output which most people seem to purely concentrate on and get 'hung up on' and nothing else. There are other considerations as BPman touched on with regards to where they are made perhaps and guarantee (for what it may or not be worth)? Which could be an issue for some. IP rating, rear finish etc. should also be looked at when spending several hundred pounds on such an upgrade NOT just puely the output alone. Q. How many people have experienced both brands and swapped either one way or the other? No need for answers on a fine quiet Bank Holiday. Let's keep it that way. Enjoy it! Off to the New Forest. Nice post Eric! ![]() Treat every day as if it is your last....one day you will be right!! |
Remember I'm ![]() ![]() Click image to enlarge ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() IID Pro MV License |
The Peak Beam Intensity number for both the Noldens and the J W Speaker Evo's is 12.5
Brendan |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Thanks Eric, good test and useful insight. I have to say, and I know this is really prissy, but given how equal they are I do prefer the Noldens based on what they look like when they are switched off....
![]() On the 'to order' list... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12.5 whats? That sort of thing is usually measured in candlepower isn't it? Total light output in lumens, intensity in candlepower? |
It is a reference number
This is taken from a North American website HERE. It is slightly out of date as it was done in 07, however in 09 (ish) the maximum beam peak intensity reference number was raised to 100. Put it crudely it is a measure of the brightest spot in the main beam. Brendan |
^^ Brendan can confirm, but I understand the following applies in the EU....
Beam Peak Intensity Reference Number This marking is found only on ECE/EEC type approved forward lighting devices that produce a high ("upper", "driving") beam, and expresses the maximum light intensity in the beam. This marking is NOT an indicator of lamp performance or quality. It does not indicate where in the beam this maximum occurs, nor does it imply anything about the shape of the beam. The marking is a number such as 10, 12.5, 17.5, 20, 25, 27.5, 30, etc. Maximum authorized total high-beam peak intensity per a vehicle under ECE regulations is 225,000 candela at 12 Volts, and many countries that adhere to ECE or EEC regulations use this marking to determine the lighting legality of vehicles in use. 225,000 candela corresponds to a peak beam intensity reference number total of 75, so many countries stipulate that all beam peak intensity reference numbers found on all devices on a single vehicle must total up to no more than 75. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
