Home > Puma (Tdci) > Do anti roll bars make much difference to the ride?
st86
England 2011 Defender 90 Puma 2.4 CSW Tamar Blue
As above i currently have a 11 plate defender without anti roll bars on and just wondering if they would be worth fitting? Off road articulation isn't really one of my concerns it does go off road every week around the farm but i don't do anything aggressive with it. How much does having them on change the ride?
Post #426074 25th May 2015 10:26am
K9F
Quite a few threads on the issue....
barbel jim wrote:
Just fitting standard roll bars will be a BIG improvement !!! I bought mine from a fellow forum member for a few ££££, Once fitted didn't see the need for anything more. Standard rears are easily available, and they are advertised on here regulary. Put up a Wanted thread, I'm sure someone will oblige you
Use the search and have a mooch about the site.....as above the 'Wanted' thread is a good idea too. Thumbs Up
http://www.defender2.net/forum/topic35658....+roll+bars If you go through life with your head in the sand....all people will see is an ar5e!!
Post #426076 25th May 2015 10:41am
Anderzander
My own experience is that If you drive through the bends so to speak - accelerating through the corners, then you won't see the difference from them so much.
When I took them off my old 90 to improve off road articulation the difference was almost solely noticeable when changing direction suddenly or with a neutral throttle - I guess you'd say in those swerving 'Oh ****!' - moments
Your spring rates and shocks will obviously play into this - but for the road I think they make a lot of sense..
Post #426084 25th May 2015 10:52am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I took mine off and the ride is much smoother (both on/off road). For off road it made the biggest difference, less jiggling about and easier to control. On road I don't see as much difference, but the ride is certainly smoother.
If you want flat cornering, then probably they work OK.
cheers
simon
Post #426092 25th May 2015 11:23am
Pickles
The prime purpose of anti roll bars is as per their domicile,..."anti roll".
So fit a good set of properly set up, & suitable, (ARB'S), & ya'll see a marked difference in the behaviour of your Defender when cornering, changing direction etc,...well ya should anyway.
Pickles.
Post #426095 25th May 2015 11:38am
