Home > Puma (Tdci) > Do anti roll bars make much difference to the ride? |
Quite a few threads on the issue....
Use the search and have a mooch about the site.....as above the 'Wanted' thread is a good idea too. http://www.defender2.net/forum/topic35658....+roll+bars If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th May 2015 10:41am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
My own experience is that If you drive through the bends so to speak - accelerating through the corners, then you won't see the difference from them so much.
When I took them off my old 90 to improve off road articulation the difference was almost solely noticeable when changing direction suddenly or with a neutral throttle - I guess you'd say in those swerving 'Oh ****!' - moments Your spring rates and shocks will obviously play into this - but for the road I think they make a lot of sense.. |
25th May 2015 10:52am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I took mine off and the ride is much smoother (both on/off road). For off road it made the biggest difference, less jiggling about and easier to control. On road I don't see as much difference, but the ride is certainly smoother.
If you want flat cornering, then probably they work OK. cheers simon |
25th May 2015 11:23am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3772 |
The prime purpose of anti roll bars is as per their domicile,..."anti roll".
So fit a good set of properly set up, & suitable, (ARB'S), & ya'll see a marked difference in the behaviour of your Defender when cornering, changing direction etc,...well ya should anyway. Pickles. |
25th May 2015 11:38am |
