![]() | Home > Puma (Tdci) > Water-in-fuel-sensor |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
good luck with fitting it as it is good extra warning system and I am sure much better than a OEM landrover one than gave problems!!! ,as you know I am one of the converted and have a Racor 230r fitted on my Puma which has saved me form serious water damage but I was interested to see some of the comments I got that implied I was stupid to fit it but all I can say is that it worked well for me!!!
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Just seen this thread, looks like the drawing I supplied for the mounting plate is incorrect
![]() Cheers, Tim Edit: I have updated the drawings, sorry for any inconvenience this has caused! |
General Lee Member Since: 09 Feb 2013 Location: Grahamstown Posts: 19 ![]() ![]() |
Good day all
Im not a frequent visitor to this site,as im more outdoors than in..... I am having trouble with my 08 Puma SW. It occurs on irregular intervals. We drive her everyday into town and back(80km round trip). Lately she seems to "splutter" on uphills mainly but also on the straight.To the point were she will only move forward at a snails pace,with the accelarator depressed all the way,but revs only to about 1500... I have changed the fuel filter,with little improvement. She then went into the stealers to check on some other minnor issues. I informed them to check up on the "spluttering" problem. They mentioned that the EGR valve "might" have a problem....After a argument over another issue, the valve was not replaced.......but HELL...THE problem seemed to disapear......Well,a couple months down the line(this day) I am having the same issues. I have now reverted to stopping her when this happens,then slowly picking up the revs(with her still spluttering) until there is a huge bunch of black smoke at the back. I do this a couple of times upto 4000rpm until she runs smooth(maby after a minute or so). Then for the rest of the trip-no probs. The next day,no problems on start up,drive 20km to town,and hit some uphill, and then the trouble starts.....Back to my idling/revving exercise,and then all fine...... PLEASE ADVISE!!!!!!!!!!!!!!! |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
Hi to everybody ! Has Nobody the correct drawing for the mounting plate ? Can you post ? Thanks ! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
Hi,
and - sorry - for me speaking: no. I remember vaguely that it was pretty easy to use some already-there-bracket as a template to dril the one hole in question. You will have no problem this way. Alternatively you could use the picture above, print it, and then take measurements and re-scale from that. But I guss, the template method is better. |
The updated one at the beginning of the thread is the correct one. Please double check the measurements to your car before making anything though! Cheers, Tim Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks
![]() The drawing is perfect for my Puma ! My Monting plate is ready ! I am waiting for Stanadyne's bowl ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
quote " The draining water is filtered and then let into the environment until the sensor notices water level is down to the desired minimun and then the drain valve automatically closes. "
looking at the kit in the picture not sure the water is drained automatic , think you have to drain manually by loosening the drain knob think it just tells you there is water in the filter |
