![]() | Home > Puma (Tdci) > 2.2 Puma one cm square rubber strip dangling under radiator |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
I believe there is supposed to be such a strip somewhere near the top of the radiator between it and the cowling? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 567 ![]() ![]() ![]() |
Yeah, had the same issue, in my case was a strip of foam that goes between the top of the radiator and the top plastic cover.
All I did was to remove the top cover and glue the strip back in place using double sided tape, job done ![]() |
![]() Click image to enlarge Does it look like this? if so, then it's as stated above and fits underneath the fan shroud. Glue they use must be quite poor, I'm thinking the shroud was taken off for the recall for the intercooler hose bracket that bolts to the side of the alternator. I also found that the lower shroud had not been clipped in properly to one of the two lower clips, so you might want to check that whilst you are there! ![]() Click image to enlarge |
I've been meaning to post a similar thread about my 2.4 because that bit of foam fell out and I couldn't find where it came from. There isn't a slot that's quite the right size anywhere!
Does it matter if left out? I've done a few thousand miles without it but could put it back somewhere. |
Have you tried fitting it in the groove under the fan shroud?
I think it's just there so stop the plastic rattling against the metal but there is also the plastic tube that links the expansion tank to the rest of the cooling system and you wouldn't want the two of them coming into contact. I'd put it back in to be sure. |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Thanks Supacat, that is the part.
![]() 88" Series One Old Norton ![]() Minerva |
