Home > Puma (Tdci) > 2.2 Puma one cm square rubber strip dangling under radiator
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi folks, I just found a cm square soft rubber strip about 20" long dangling from the area below the radiator.
Anybody got any idea where it came from Question
Thanks. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #425423 21st May 2015 9:47pm
nickhodgson
I believe there is supposed to be such a strip somewhere near the top of the radiator between it and the cowling? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #425475 22nd May 2015 8:16am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Yeah, had the same issue, in my case was a strip of foam that goes between the top of the radiator and the top plastic cover.
All I did was to remove the top cover and glue the strip back in place using double sided tape, job done Thumbs Up
Post #425476 22nd May 2015 8:31am
Does it look like this?
if so, then it's as stated above and fits underneath the fan shroud. Glue they use must be quite poor, I'm thinking the shroud was taken off for the recall for the intercooler hose bracket that bolts to the side of the alternator. I also found that the lower shroud had not been clipped in properly to one of the two lower clips, so you might want to check that whilst you are there!
Post #425505 22nd May 2015 10:26am
Cupboard
I've been meaning to post a similar thread about my 2.4 because that bit of foam fell out and I couldn't find where it came from. There isn't a slot that's quite the right size anywhere!
Does it matter if left out? I've done a few thousand miles without it but could put it back somewhere.
Post #425553 22nd May 2015 1:25pm
Have you tried fitting it in the groove under the fan shroud?
I think it's just there so stop the plastic rattling against the metal but there is also the plastic tube that links the expansion tank to the rest of the cooling system and you wouldn't want the two of them coming into contact.
I'd put it back in to be sure.
Post #425556 22nd May 2015 1:42pm
Natlas
Thanks Supacat, that is the part.
Thumbs Up 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #426229 25th May 2015 8:54pm
