![]() | Home > Puma (Tdci) > Air suspension kit |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
funnily enough im working at Dunlop air suspensions! very interesting business
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Was it a big job or relatively straight forward? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Autoairride Member Since: 18 Apr 2014 Location: Nth Norfolk Posts: 10 ![]() ![]() ![]() |
Pretty straight forward... I had the spacer rings for the top spring mounts cnc cut at a local engineers. I think they were amount 12mm thick. The front shock mounts are just a twin mount kit using just the outer mount. The classic air bags fitted straight on to the axles, they even had the locating holes stamped into the spring mounts. The control gear was bought as a package with very good install info, plus the ridetech website is full of air ride info. The only other thing is if you use classic air bags then std height shocks have to be used to limit the travel of the air bags. I also fitted the classic lse bump stops as they are a bit softer for when you want to go for that 'slammed' look.
![]() Hope this helps ![]() |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
This is all very good reading and this maybe a couple of silly questions.
Are there any problems with propshafts sliding joint length at extreme points of suspension travel, Steering draglink, brake flexy hoses. ect. The idea of a slammed landy for novelity sakes does seem interesting rather than 4 foot of the ground. Or looking like something out of mad max. if you know what I mean Forgot to add if it gets me into a multy story car park it would be worth the money, come on warranty run out soon. |
http://www.accuair.com/classic/products/ai...tems%3A252
accuair the best in the business for the control system. RRC air bags as described earlier front and rear. the tricks with arbs and length and adjustabiity of dampers |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
The very best of good fortune to those who go down the inflationary road, but one of the main reasons I sold the Disco 2 was because of expensive problems with the air suspension. Although they are completely different vehicles no regrets changing to the 110 CSW, and no significant difference in the ride - certainly none which would justify a mod. But - each to his own. One wife - livid
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2230 ![]() ![]() |
Maybe you could try this .
A it tricky with the caravan hitched up? One wife - livid
If you keep the shocks at std length then everything still operates within the original tolerances that are there with the std springs. I regularly have to operate mine with the front at max height and the rear at minimum height for manoeuvring/siting static caravans and I have never had any problems with props or brake hoses. As for the slamming idea, it looks great when you dump all the air out, but the ride is a bit firm ![]() The key to a successful set up is attention to detail on the installation. Making sure the air lines are never going to get damaged by rubbing on other parts of the vehicle or each other. Double check everything through the complete scope of the suspension and steering travel. Use plenty of sealant on threaded connections and make sure all the wiring is fitted to as close to oe std as possible. Oh don't forget to declare the modification with insurance! Mine has so many mods, another one didn't seem to be a problem. Good luck ![]() |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 ![]() ![]() |
I have run accuair with my 2012 110XS for a year, stock height feels the same as springs, most use is access height for carparks. It has self levelling system so the vehicle stays same level no matter the load. When I am camping on uneven ground, I can adjust each spring individually so my roof top tent is level.
any pics ronwong?
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Another nudge as I've been on the hunt for some "aired" defender pics!
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Hi Guys
Check out Marant Air, not sure if this is exactly what you are looking for but hope it helps ![]() http://marantlandrover.com/ Best Regards Alex Divers ![]() |
