Home > Puma (Tdci) > Air suspension kit
Page 2 of 2 <12
T1G UP
funnily enough im working at Dunlop air suspensions! very interesting business
Post #321583 4th Apr 2014 5:59pm
Autoairride
United Kingdom 2002 Defender 90 Td5 HT Auto Chawton White
Probably a bit late to jump in on this one.. But it might help.
I've been using full air on my 90 for 7 years now with no regrets. I used RR Classic air bags, which fit straight onto the axle casings. A small spacer ring was fitted to the top spring mount to allow the air bags to fit without cutting the original mounts. I uprated the rear anti roll bar, fitted rancho adjustable shocks all round (the front ones are fitted to a twin shock mount kit to relocate the shock to fit alongside the air bags), and the whole lot is controlled by a ridetech ridepro e2 system. The system has level sensors so you can preset three different ride heights and adjust each bag individually.
I wasn't cheap, but I use mine for my work, siting static caravans and twin unit lodges so the benefits outweighed the time and expense involved.
Post #324774 19th Apr 2014 8:56pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Was it a big job or relatively straight forward? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #324796 19th Apr 2014 11:31pm
Autoairride
Pretty straight forward... I had the spacer rings for the top spring mounts cnc cut at a local engineers. I think they were amount 12mm thick. The front shock mounts are just a twin mount kit using just the outer mount. The classic air bags fitted straight on to the axles, they even had the locating holes stamped into the spring mounts. The control gear was bought as a package with very good install info, plus the ridetech website is full of air ride info. The only other thing is if you use classic air bags then std height shocks have to be used to limit the travel of the air bags. I also fitted the classic lse bump stops as they are a bit softer for when you want to go for that 'slammed' look. Wink Sometimes the ride height misses the preset, but I put it down to suspension 'bind' as I am using polybushes. Choosing the preset once on the move usually sorts this.
Hope this helps Thumbs Up
Post #324855 20th Apr 2014 10:31am
martinfiattech
This is all very good reading and this maybe a couple of silly questions.
Are there any problems with propshafts sliding joint length at extreme points of suspension travel,
Steering draglink, brake flexy hoses. ect.
The idea of a slammed landy for novelity sakes does seem interesting rather than 4 foot of the ground.
Or looking like something out of mad max. if you know what I mean
Forgot to add if it gets me into a multy story car park it would be worth the money, come on warranty run out soon.
Post #324880 20th Apr 2014 1:03pm
T1G UP
http://www.accuair.com/classic/products/ai...tems%3A252
accuair the best in the business for the control system.
RRC air bags as described earlier front and rear. the tricks with arbs and length and adjustabiity of dampers
Post #324888 20th Apr 2014 2:46pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
The very best of good fortune to those who go down the inflationary road, but one of the main reasons I sold the Disco 2 was because of expensive problems with the air suspension. Although they are completely different vehicles no regrets changing to the 110 CSW, and no significant difference in the ride - certainly none which would justify a mod. But - each to his own. One wife - livid
Post #324900 20th Apr 2014 3:49pm
keith
Maybe you could try this .
Post #324954 20th Apr 2014 7:34pm
IanW
A it tricky with the caravan hitched up? One wife - livid
Post #324955 20th Apr 2014 7:42pm
Autoairride
If you keep the shocks at std length then everything still operates within the original tolerances that are there with the std springs. I regularly have to operate mine with the front at max height and the rear at minimum height for manoeuvring/siting static caravans and I have never had any problems with props or brake hoses.
As for the slamming idea, it looks great when you dump all the air out, but the ride is a bit firm Laughing But it has helped me get under certain obstacles. I'm not keen on the mad max look either.
The key to a successful set up is attention to detail on the installation. Making sure the air lines are never going to get damaged by rubbing on other parts of the vehicle or each other. Double check everything through the complete scope of the suspension and steering travel. Use plenty of sealant on threaded connections and make sure all the wiring is fitted to as close to oe std as possible. Oh don't forget to declare the modification with insurance! Mine has so many mods, another one didn't seem to be a problem. Good luck Thumbs Up
Post #324978 20th Apr 2014 9:04pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I have run accuair with my 2012 110XS for a year, stock height feels the same as springs, most use is access height for carparks. It has self levelling system so the vehicle stays same level no matter the load. When I am camping on uneven ground, I can adjust each spring individually so my roof top tent is level.
Post #410498 24th Mar 2015 12:04pm
T1G UP
any pics ronwong?
Post #415340 11th Apr 2015 9:50am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Another nudge as I've been on the hunt for some "aired" defender pics!
Post #425109 20th May 2015 12:58pm
Alive Tuning
Hi Guys
Check out Marant Air, not sure if this is exactly what you are looking for but hope it helps Very Happy
http://marantlandrover.com/
Best Regards
Alex Divers Thumbs Up
Post #425110 20th May 2015 1:01pm
Page 2 of 2 <12
