Home > Td5 > Td5........lack of boost
JimboD3
United Kingdom 2003 Defender 110 Td5 HT Bonatti Grey
Morning all,
My '53 plate Td5 110 seems to be lacking in power - it's never had a really high top speed, but has always been resonably quick in getting to 60mph, lately though it seems to be really 'sluggish' and whilst it still gets to 60+, it doesnt fly quite like it used to.
What I've done to investigate so far:
Disconnected the MAF sensor - no real difference in performance noticed
Replaced the MAF sensor - had a known working spare 'in stock' anyway - no real difference noticed
Changed the fuel filter - it was weeping a bit from the top, no difference noticed
Cleaned the MAP sensor - it didnt appear to be gunked up (EGR went walkies a long time ago)
Cleaned the AAP sensor - no difference noticed
Replaced the air filter - used an original, new LR one.
Checked that the turbo wastegate actuator moves (with a pair of grips)
Other than the EGR being blanked, the engine is standard - no remap, no big intercooler, no silicone hoses etc......and there's no smoke when trying to accelerate hard (which I thought there would be if one of the hoses was collapsing ?), but I do have a Safari RAI fitted (and it always has been fitted)
The engine starts fine, and idles fine, you pull away and there's virtually nothing........foot to the floor.....and not a lot, and then slowly it starts to pick up..........and then into 2nd and it feels 'flat' again, but eventually it begins to pick up - it's almost as if the turbo is not boosting (I think !)
I've got a first gen Nanocom - no faults are logged (other than the usual A/C ones etc) - I've searched all over the t'internet for some real time values to compare my readings against, but that sort of info seems to be really hard to find.
The reading that the Nancom gives for the 'turbo wastegate modulator' is zero at idle (which I belive is correct), rising to 40.00 with foot hard down in 3rd going up an incline on a dual carriageway - does anyone know what the value represents ?
Whilst having another prod around the engine bay this weekend, I noticed that the air inlet hose (the one from the air box to the turbo - with the MAF sensor in it) seems to be very 'squashable' at the sharp bend where the hose reduces to fit onto the turbo - is this ok, could it be squashing down as the turbo tries to spool up ?
Any ideas, suggestions, Nanocom values will be gratefully received.
Jim Td5 110 HD Hardtop.......not quite standard Smile
Post #425030 20th May 2015 10:27am
mk1collector
Have you checked for oil in the red plug on the ecu? Ray
My build thread
Post #425061 20th May 2015 11:33am
K9F
Hose 'collapse' is an issue that has been experienced if you do a search on the internet and for a small outlay could be negated as the cause or even cure it perhaps? The issue of oil ingress in the injector harness is well documented on here as a cause of power loss too!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425062 20th May 2015 11:38am
JimboD3
Hmm, oil in the injector harness...........I replaced the harness a couple of years back as it was just starting to leak into the multiplug on the underside of the head, but hadn't got to the ECU. It's not something I've checked for a while - will investigate that later today.
Remind me - do you need to disconnect the battery to remove/check the red plug ? Td5 110 HD Hardtop.......not quite standard Smile
Post #425065 20th May 2015 11:46am
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Is there anyway to know if the turbo is dead?
Jimbo, I disconnect the negative cable every time I remove the red plug!
Post #425132 20th May 2015 4:29pm
JWL
Whereas I never disconnect the battery, ignition is off though i.e. the key is out.
Post #425147 20th May 2015 5:52pm
Fatboy Slim
Wales
Take your cat off and give it a run down the road. See if it goes any better.
Post #425213 20th May 2015 9:54pm
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
fuel pump dying? stuck fpr? blocked fuel lines?
Post #425250 21st May 2015 12:41am
JimboD3
Ok, so have spent some time investigating this problem a bit further........
1. No oil in the red ECU plug
2. No oil in the injector loom connector front left of the head
3. Turbo wastegate actuator linkage disconnected and confirmed that the wastegate moves freely in the turbo
4. All turbo/intercooler hoses checked for 'secureness'
5. EGR valve replacement tube removed and checked - I thought there was a small trace of oil leaking where the lump of billet joins the inlet manifold.......checked both surface for 'flat' and made a new gasket.
6. Got SWMBO to floor the loud pedal whilst I watched the I/C hoses - nothing appeared to collapse, but then maybe it needs to be under a proper load ?
7. Went for a test drive - still the same..........Nanocom readings were (from memory):
MAF - a max of around 450 (Kpa ?)
Inlet manifold pressure - a max of just over 200 (Kpa?) seen in 3rd gear foot flat on the floor
There's no rough idle or rough/lumpy running - it just doesnt pick up speed like it used to..............which to me doesnt seem like a fuelling problem - but could it be ?
Post #425945 24th May 2015 6:05pm
dorsetsmith
fuel presser ?
is the tubo ok i.e not exces play or score marks as if the compressor rubbing and jamming ?
Post #425950 24th May 2015 6:36pm
K9F
Could still be collapsing hoses perhaps? Under load as you mentioned which cannot be checked stationary unless you've a rolling road. are they in good condition with no 'soft spots' or delamination? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425957 24th May 2015 6:59pm
Fatboy Slim
Wales
Take the cat off Whistle
Post #425976 24th May 2015 9:02pm
K9F
I think he heard you the first time! Whistle
Catalytic convertor is not the main issue here though is it? Undoubtedly it will pick up quicker with the rapid spool up of the turbo but it could potentially mask the root cause of the problem. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #426000 24th May 2015 10:38pm
Fatboy Slim
Wales
I've had a few blocked lately giving the same fault. One was so bad it wouldn't even start.......
Post #426004 24th May 2015 10:55pm
grafty99
Missed that sticky wastegate had been mentioned Embarassed 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #426017 24th May 2015 11:28pm
