Home > Maintenance & Modifications > Extended mirrors for towing |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 |
De nada mi amigo.
10th Oct 2010 3:59pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
Why is it a legal requirement?
11th Oct 2010 2:54pm |
Never heard of that one -
I tow this around - Not had any problems yet. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Oct 2010 3:15pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Ignorance of the law is no excuse. If you can see clearly to the rear of whatever you are towing then you don't need extended mirrors. i.e. It's the same width or narrower than the towing vehicle. Last edited by Laurie on 11th Oct 2010 5:32pm. Edited 1 time in total |
11th Oct 2010 3:19pm |
i'll have a look into that then
the RIB has a beam of 2.8m so alot wider than the Defender |
11th Oct 2010 4:13pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Hi there!
Thanks for all you help but finally I decide to give up the auction. 29 GBP + post for each sound quite expensive. Thanks in advance I will see another solution. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
11th Oct 2010 5:23pm |
I'f I come across any more at £12 each, would you like me to buy some?
I could always sell them on if you changed your mind. |
11th Oct 2010 5:36pm |
Taken from the direct.gov.uk website
The "wolf" XD longer mirror arm is part # RRC 8443. not sure how much is it from LR, prolly quite a bit, but it's the same arm used on some Leyland/DAF vans (like the Post Office use), so you may get one from a DAF dealer or breakers (same thing isn't it? ) |
11th Oct 2010 6:24pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Eduardo,
I will be going back to work at the end of the month- I will see what I can find for you (You will probably have to pm me on the 1st Nov) Glyn |
11th Oct 2010 7:22pm |
I know lots of people who break things but not many dealers. |
11th Oct 2010 9:32pm |
I know dealers who break things! |
12th Oct 2010 7:02am |
Thanks guys for all your help.
Glyn, Laurie if you found a pair below 20£ each will be great. We will keep in Touch. Thanks again Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
12th Oct 2010 12:08pm |
[quote]Fit towing mirrors if you need them If your caravan or trailer is wider than the narrowest part of the rear of the towing vehicle, you must by law fit towing mirrors. These mirrors must be E-marked (mirrors with this mark meet EU requirements).[quote] Thats ok then, because the trailer is the same width as the Defender. |
13th Oct 2010 3:13pm |
....but can you see clearly to the rear?
13th Oct 2010 3:37pm |
