Home > Technical > Fluid leak coming down the inside of the passenger wheel |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Sounds like calliper seals, or a brake line that's leaking?
Check you fluid level, and get it sorted ASAP! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
13th May 2015 9:30pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Failing swivel seal will leak onto the inside of the tyre generally worse if it's an earlier model with oil filled swivels. Steve.
13th May 2015 9:54pm |
Landydefender1 Member Since: 13 May 2015 Location: East Yorkshire Posts: 63 |
It's a 2003 90
14th May 2015 6:45am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
It could also be a failed hub seal.
14th May 2015 7:30am |
Going to take it to Bob Trice Beverley East Yorkshire......... The joy of owning a Defender is now upon me....
14th May 2015 9:00pm |
