Home > Technical > Fluid leak coming down the inside of the passenger wheel
Landydefender1
United Kingdom 2003 Defender 90 Td5 HT Rioja Red
looked underneath tonight and found a leak off fluid that is coming down the inside of the passenger wheel?
What might be above it that would leak?
Any help or advice would be appreciated.
Post #423333 13th May 2015 9:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Sounds like calliper seals, or a brake line that's leaking?
Check you fluid level, and get it sorted ASAP! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #423338 13th May 2015 9:30pm
Happyoldgit
Failing swivel seal will leak onto the inside of the tyre generally worse if it's an earlier model with oil filled swivels. Steve.
http://forums.lr4x4.com
Post #423345 13th May 2015 9:54pm
Landydefender1
Leak
It's a 2003 90
Post #423376 14th May 2015 6:45am
It could also be a failed hub seal.
Post #423387 14th May 2015 7:30am
Landydefender1
Going to take it to Bob Trice Beverley East Yorkshire......... The joy of owning a Defender is now upon me....
Post #423632 14th May 2015 9:00pm
