![]() | Home > Off Topic > Any Fiat experts on here? |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Was having my tracking checked the other day and got chatting to the other chap waiting. He was having a new sump fitted to his fiat. Not sure if same model as yours but said it was quite common.
Can see this post generating some reverse jokes ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
I think the forum member "martinfiattech" could possibly know
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5930 ![]() ![]() ![]() |
I thought there was a Fiat themed user name on the forum..Unless is it part Italian and his family name is Fiattech.... 1999 Defender TD5 110
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
My brother and his partner run a Alfa Romeo garage,
Only working on Italian cars, and motor bikes, what he doesn't know about Fiats and Alfas isn't worth knowing! I'm seeing him tonight, I will as the question......... ![]() Wanted, Forward Control Anything considered. |
Thanks. I had a quick look at the car on the way home. Looks like its had paint job on the rear (badly, or it could be faded/patchy paintwork) the front head light/bonnet dont line up like the other side and the keyfob gave me odd moments. Pressing the fob to lock, sounded like it did but still unlocked. Pressed the unlock and then relock and then locked.
But in the bills, there is the usually cam belt, water pump and also two new number plates.... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Right, had a chat with brother.
Apparently, the gear box bearings are made of the finest Italian ice cream!, they DO fail eventually. Power steering column, ECU can give a few problems? (Typical fiat, Alfa problem so I'm told!) Apart from that and oil leaks, and the usual wear, that's about all I was told. Doesn't sound too different from owning a Land Rover... ![]() Good luck 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Thanks Ian. 1999 Defender TD5 110
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1033 ![]() ![]() ![]() |
Have you looked at Honest John http://www.honestjohn.co.uk/carbycar/fiat/...ction=good Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Thanks I will take a look. 1999 Defender TD5 110
