Home > Puma (Tdci) > Suitable brake fluid
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Time to change the brake fluid but nothing here in Tanzania meets the spec needed.
Plain DOT 4 is available but as it is made here, it doesn't match up with the of the technical spec for the DOT 4 mentioned in the manual.
Will it do? If not, what are the consequences?
Grateful for any input.
Thanks, David
Post #305860 7th Feb 2014 11:10am
MK
I used std DOT4 and no problems over 2 years. Puma 110" SW
Post #305867 7th Feb 2014 11:42am
munch90
do what most garages and dealers do just suck the bit out the master cyl bottle and top up with clean .. not seen many places do it by bleeding on each wheel as you should
Post #305873 7th Feb 2014 11:54am
davidpalfreyman
Thanks very much for your input
David
Post #308917 17th Feb 2014 5:31pm
sraosha
Switzerland
Re: Suitable brake fluid
Thanks, David
Hi David,
Same question here, same location. Are you in Msasani? In the worst case you can ask and buy at CMC - just don't go for their 2million Tsh services.
Cheers,
Claus
Post #422042 8th May 2015 2:30pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
We do [well - I certainly do, Can't speak for other Engineers lol] Guns and Landrovers .... anything else is irrelevant.
Post #422052 8th May 2015 3:01pm
