![]() | Home > Puma (Tdci) > Suitable brake fluid |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2449 ![]() ![]() ![]() |
I used std DOT4 and no problems over 2 years. Puma 110" SW
do what most garages and dealers do just suck the bit out the master cyl bottle and top up with clean .. not seen many places do it by bleeding on each wheel as you should
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 ![]() ![]() |
Thanks very much for your input
David |
sraosha Member Since: 30 Apr 2015 Location: Dar es Salaam Posts: 29 ![]() ![]() |
Hi David, Same question here, same location. Are you in Msasani? In the worst case you can ask and buy at CMC - just don't go for their 2million Tsh services. Cheers, Claus |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
We do [well - I certainly do, Can't speak for other Engineers lol] Guns and Landrovers .... anything else is irrelevant. |
