Home > Puma (Tdci) > Water in air filter of 2013 PUMA? |
If you've not been wading, the water must have been sucked in
Open your airbox up, at the bottom there is a drain hole, make sure it's not blocked |
30th Apr 2015 6:25am |
Floppy Member Since: 30 Apr 2015 Location: Northern NSW Posts: 4 |
Thanks mate - I'll do that! The dealer has since replaced the filter but didn't mention anything other than deepwater crossings?
30th Apr 2015 6:31am |
air filter box lid not fitted right ?
30th Apr 2015 7:33am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
That's exactly what I was thinking Munch90. Same thing happened to my 2010 Puma and the lid hadn't been fitted under the back clips allowing water ingress which ruined the filter. Main stealer job of course.
To check take off the blank cover on the wing and shine a torch up there with a small mirror and if you can see filter material it's not fitted right. To fit correctly you can either push the replacement filter element right down into the housing then slide the top back on or do as I do: Fit filter into top cover and while standing alongside the left wing bring it towards you with the far end tilted up, feed it carefully underneath the aircon hose and keep gently pulling it back towards you. The last few leaves of the filter will need to be pushed back towards you but once they're in the filter lid will drop down and you'll find it's secure under the back tabs and can then be clamped down with the front clips. I think most of the people they use here in Oz are either young unsupervised apprentices or refugees from unspeakable places who've never worked at any thing let along on modern vehicles. Can you call a Deafener modern? Hope this helps. AlanH. |
30th Apr 2015 7:49am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20314 |
Pressure washer used around air vent?
30th Apr 2015 3:14pm |
AlanH - similar technique but not sure why you put the filter in the lid - it works fine on mine with the filter in the base which means it's not proud of where the lid slides across.
30th Apr 2015 4:59pm |
Thanks all for your suggestions - I picked the car up yesterday and when I finished work it was raining again (though not as heavily). I made it to the exact same spot (about 5km from my office) when, you guessed it, same engine light and no power?!? Its back at the dealer now?? I will call and suggest poor fitting filter cover as you guys have also suggested! Will let you know how it goes?? At least they now know I wasn't driving though any flooded rivers!!
30th Apr 2015 10:48pm |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 |
2008 Puma, I have the same concern, after a pressure clean, did it twice to prove it, I have a snorkel and am to investigate further, seems to be sealing, but will do the check through the plastic bit on top of guard as advised by previous post. WMcA Brisbane Australia
Defender 2.4 Puma 2009 “Airbags! The other vehicle is my crumple zone!" |
30th Apr 2015 11:11pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
you guys must be from sydney.
the puma air duct is not sealed. so water can sucked into the engine I have done my airbox mod and always use pressure washer in the engine bay and never had a problem- that is if you make the air duct water tight |
30th Apr 2015 11:24pm |
Thanks for that, as soon as it stops raining I will check out the whole thing again must have missed something. It is a little late in UK, 0030hrs to be on the nett! WMcA Brisbane Australia
30th Apr 2015 11:31pm |
Thanks for the suggestion - how do you make the airbox watertight? I have just returned from the dealer and it was water in the air filter again - surprise, surprise!? At least they no longer think i was driving it through rivers between me picking the car up and leaving work! ha - Sydney no, northern NSW....just about to get another solid east coast low weather system (mini-cyclone for other readers!!). >200mm of rain forecast!! |
1st May 2015 1:02am |
