Home > Technical > Does anyone know what thread this is?
shaggydog
Hi Guys,
I am looking at making up a fuel pick-up point for my Webasto for the up coming cold and chilly summer months Rolling Eyes
Does anyone know what thread this part is?
I imagine it is some sort of pipe thread but I want to know so I can get a fitting bought then machine a hole through the middle so I can drop a fuel pickup pipe down it.
Unless anyone knows of a better way of doing it?
Pipe in question is on a 200Tdi metal fuel tank.
Red arrow Thumbs Up
As always all suggestions and helpful comments welcome! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #420188 30th Apr 2015 2:40pm
Romadog
That is a blank fitting for the bare tube on the tank. Possibly M8 thread? It will only be any good if the pipe goes down inside. It maybe only a breather type pipe.
Is your engine fuel supply taken from the other side via the sender unit ??
http://new.lrcat.com/#!/1228/20326/20390/1598/21273
Post #420190 30th Apr 2015 2:51pm
munch90
have you not got a spare outlet on the fuel filter
thought the 200tdi fuel filter housing had some outlet that had blanking plugs fitted
Post #420192 30th Apr 2015 2:55pm
shaggydog
Thats the plan to make make a plug fitting which has a pipe on the inside which will go down into the bottom of the tank to pickup fuel Thumbs Up
The supply and return goes ontop of the tank and I'd rather not play with them as they are notoriously brittle on older trucks.
I want to try and keep the webasto fuel system as separate as possible from the engine fuel system to minimise on reliability issues for both items. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420193 30th Apr 2015 2:56pm
shaggydog
I didn't know they had them munch?
Where would that be on the filter? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420194 30th Apr 2015 2:57pm
munch90
im not 100% , but have you got a pic of filter housing
isn't it the screw on filter type
some filters have arrows on to showing which are ins and outs
Post #420195 30th Apr 2015 3:01pm
shaggydog
yes your correct screw on type Thumbs Up
I don't have a pick but I have done a quick google search and yes I think your right!
Do you think it would be ok to fit another banjo bolt with a pipe to feed the webasto?
I can put in a non return valve which should stop any air issues?
If yes what do I need to buy?
Or would it be better to go straight to tank?
Sorry for so many questions Embarassed Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420201 30th Apr 2015 3:05pm
munch90
you have a lift pump on a 200 tdi so filter is fed from the pump , could this be a problem ??
has anyone done it , ie fed heater from filter ? someone maybe along later who has
are you having the heater running without engine running ?
Post #420209 30th Apr 2015 3:56pm
Romadog
With my 110 my sender is on the l/h side. I was going to swap with a sender that has a pickup pipe as well such as AMR1495
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1140361578
Post #420243 30th Apr 2015 6:43pm
shaggydog
It could be a problem, in all honesty I have no idea Laughing
Here are the pics of the filter housing Thumbs Up
Success it does have a unused feed point Very Happy
Bad news is it looks like its an inlet rather than a outlet.
So I think its back to the fuel tank for answers?
I want to use it as a block pre-heater so have it running without the engine running, having said that would be good to be able to run it as a supplementary heater. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420244 30th Apr 2015 6:45pm
shaggydog
Ohh good spot Romadog Thumbs Up
Will have a look but from memory the plug looks different.
Will report back Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420245 30th Apr 2015 6:52pm
shaggydog
Bother!
Looks like the pickup is on that side already. Evil or Very Mad
Looks like ether pickup goes in the side and return comes in the top, or vice versa.
Hummm.
I don't really want to drop the drop the tank for the purposes of "having a look". Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420252 30th Apr 2015 7:06pm
munch90
eBay Item No. 271310141294
Something like this , in through the sender
Post #420260 30th Apr 2015 7:21pm
shaggydog
Looks interesting, would you have to remove the existing one sender? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #420267 30th Apr 2015 7:43pm
munch90
The ones ive seen fitted in the ambulances we do , looks like you take the sender out , drill hole in sender , fit pipe with nut on inside to hold pipe tight , refit sender , of course making sure its sealed and pipe goes down in to diesel
personally never fitted one so all guess work , but must come with fitting instructions to follow
someone on here must have fitted one !
Post #420270 30th Apr 2015 7:51pm
