Home > Technical > Does anyone know what thread this is? |
Consider THIS OK not as cheap as the ebay offerings but saves dropping the fuel tank.
We can supply these to order. Brendan |
30th Apr 2015 8:03pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Thanks Guys.
Munch, just thinking that is basicly what I want to do with the pipe in the beginning? Leeds, I had thought about that item but I'm hopeing soon to add a wing tank so would have to come out again which would make it an expensive exercise. Thanks for the tip though Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
30th Apr 2015 9:48pm |
Thanks Brendan
I want to go with a wing tank at some point in the longer term future hence why I don't think the nakatanga part will be suitable for my needs. I don't want to go for the 120l tank as you have quite rightly pointed out you have to change the towing arrangements and that makes an expensive item even more expensive! I really don't need a rear winch and not sure I can even fit one as there isn't much space behind the fuel tank and the crossmember, plus I should probably put one on the front before I do the back! But again that's for later on in the scheme of things. Right now I want to get the heater plumbed in and set up so I can look at doing some snowboarding in the winter months and be warm in the winter here. I basically want to find the thread of the tiny pipe pictured at the beginning of the tread so i can make up a fitting which i can screw into it and feed a pickup pipe down it and then use that as the pickup pipe for the heater as to my mind it is the simplest way of doing it surely? Something like this With the thicker part screwing into the tank, the thinner part facing outwards with the pickup pipe pushed through then glued/fixed in place so I can screw a coupling onto it which will accept the feed pipe to the heater? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
1st May 2015 12:08pm |
