Home > Technical > What's missing?
Martin
Site Admin
What's missing?
What's missing on my 90 where the seat box bolts to the rear tub?
I have a gap here out to the wheelarch which has let muddy, salty water into the sill area over the winter.
Both sides are the same.
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #419405 27th Apr 2015 12:38pm
munch90
just sealer missing I think your find
something like the old style dum dum
Post #419406 27th Apr 2015 12:41pm
shaggydog
Dab of sealant I'd imagine. Laughing
Though I think on mine there is a seat belt bracket there? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #419407 27th Apr 2015 12:42pm
AndrewS
Nothing that's just a build tolerance gap Thumbs Up 130's have feeling's as well you know Smile
Post #419413 27th Apr 2015 1:03pm
Martin
Site Admin
Er right - so it is perfectly OK for water to come in through it then and corrode the sill?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #419414 27th Apr 2015 1:04pm
"they are all like that sir" Shocked
Post #419416 27th Apr 2015 1:06pm
shaggydog
Oh no your right its definitely not ok.
But it is a defender?
Take it to your dealer and make the point of saying lots of salty water is coming out of it and then make sure they clean it properly, treat any rust appropriately and then seal it properly.
Interestingly, having a look at my one yours seems to have a different seat belt arrangement as mine has a plate which bolts to the B pillar and the floor and then the seat belt attaches to that.
Will take a pic and upload when I'm home if it helps? (I can't plug my phone into the work pc's Embarassed ) Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #419418 27th Apr 2015 1:10pm
Martin
Site Admin
This is on the new (15MY) 90, so the end of the belt loops back to the plate with the reel on it.
The soft top (1988) has (had) the bracket in the bottom corner.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #419419 27th Apr 2015 1:12pm
munch90
built quality is going down and down , god knows what the last ones will be like !
Post #419422 27th Apr 2015 1:15pm
Martin
Site Admin
Thanks for the replies Thumbs Up
Will raise it further with the dealer, at least I know there's not just a seal plate missing or similar.
2015 D90 XS SW
Post #419424 27th Apr 2015 1:16pm
shaggydog
If its any consolation my one has a plate in the bottom of it and is maybe 5-6mm deep with dust and old mud which until now I hadn't noticed. Shocked
Hope it gets sorted Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #419425 27th Apr 2015 1:19pm
X4SKP
Re: What's missing?
Hello Martin
Answer... build quality... Shocked
Mines is similar on one side, but tighter on the other.
You can see also on your Drivers Side image that the bolt head 'north' of the location has a elongated hole
in the panel work where I would guess that there is a generally assembly first, then a general alignment process before things are tightened up.
Defenders as we know have worked on the principle of 'there or there abouts' for years, which I don't mind too much as long as function wins out. My 90 (MY2011) has an almost closed gap near side and a 7-8 mm gap drivers side. But on both sides there is evidence of a gasket / seal behind this assembly. Neither let in water. I noticed this when preparing / power washing the underside before the Dinitrol treatment.
So I would say that it is worth going back to the Dealer, but you will probably get a silicon / water ingress 'quick fix'... make sure it's really clean and dry when you take it in as this will principally determine how long the fix lasts.
Good Luck... Thumbs Up
Drivers Side 7-8 mm Gap with rear 'Seal'
Off Side Tighter but also with rear 'Seal' SKIP
Post #419439 27th Apr 2015 2:10pm
roel
My 2003 has the same now. While cleaning before painting I push some chewing gum look alike away and now I have the same hole on both sides. Whistle Roel
2003 90 Td5 (2009-now)
Post #419489 27th Apr 2015 5:09pm
AndrewS
Check to see how many loose bolts you have as well Thumbs Up 130's have feeling's as well you know Smile
Post #419493 27th Apr 2015 5:19pm
munch90
land rover might have done it on purpose to let rain water out that comes though the windscreen joint Laughing
Post #419496 27th Apr 2015 5:27pm
