Home > Puma (Tdci) > bleeding / changing brake fluid
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i know your supposed to plug the car in and get the abs system to pump through the brake fluid when bleeding as per the manual; but is there any reason why i cannot just connect my vacuum bleeder up to the nipple and suck the new fluid through?
 1953 80"
1987 mini city e
2011 90"
Post #388872 15th Jan 2015 10:41pm
jimbob7
imo,if there is no air in the system (just changing fluid) I don't see a problem just using a vacuum/pressure bleeder Pov.spec,ftw. 2006, 110,TD5.
Post #388879 15th Jan 2015 10:53pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I've always bled my brakes the old fashioned way ( abs Td5) with a pipe and receptacle at the calliper and pumped through with the pedal, I always start with the brake furthest from the master cylinder and and then the next furthest etc. Never had a problem with this method. 2005 Td5 90 XS
Steve
Post #388886 15th Jan 2015 11:04pm
martinfiattech
You`ll be fine using a vacuum bleeder, just don`t forget to drain / suck out the fluid from the reservoir and add fresh before bleeding. It`s amazing how many people don`t do this. As long as you leave a little in their so no air gets in.
Also start from the furthest from the master cylinder. Check for a good firm pedal before driving off
As for using the abs pump to do the work, it`s more for bleeding the valve body it`s self.
You can use the same kit for changing the clutch fluid, as it`s the same stuff. Be warned it drains the reservoir QUICK.... Excuse the spelling I`am better with spanners and wires.
Post #388890 15th Jan 2015 11:11pm
MR_JAMES
ah ha!! no problems then i will give it a go. Thanks for info.
clutch reservoir looks the same as my old 109... apart from the switch on top. Will do that to as i got a good deal on a 5 litre container of brake fluid with my halfords trade card. 1953 80"
1987 mini city e
2011 90"
Post #388907 15th Jan 2015 11:49pm
MR_JAMES
So i tried to do it yesterday. No such luck; theres to much resistance while sucking the fluid down the line that you pull air past the threads of the nipple. I tried sucking it though with my mouth (i know its not healthy) and could feel resistance.
I got around it by running the engine and pumping fluid through the traditional way. worked perfectly. 1953 80"
1987 mini city e
2011 90"
Post #418640 24th Apr 2015 12:25pm
munch90
When you open the nipple the fluid should just drip out there should be no rresistance
Better pressure bleeding to vac bleeding anyway
Post #418644 24th Apr 2015 12:43pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
I used exactly the pump you show and it worked fine but took a long time causing my selfish neighbour to come and complain about the compressor running. I'd be very interested to hear how you use the abs to do it.
Post #418757 24th Apr 2015 7:15pm
Anderzander
I could do with a vacuum pump - is that one you'd recommend ?
Post #418800 24th Apr 2015 9:47pm
munch90
I have both vac and pressure bleeders , but always use the pressure bleeder as does a better job
But pressure bleeders are more expensive
Post #418812 24th Apr 2015 10:22pm
Anderzander
Could you recommend one (a pressure bleeder that is) ?
Post #418859 25th Apr 2015 7:00am
munch90
something like this
eBay item number:
eBay Item No. 311344688722
pressure bleeder
and the cap supplied fits the defender Thumbs Up
and think that's a good price I paid a lot more for mine Crying or Very sad
Post #418891 25th Apr 2015 10:17am
MR_JAMES
personally i've not had that much luck with it. It depends on a number of factors -
1. you need the right air pressure. i.e. not to high!
2. You need a good seal between the nipple threads and cylinder.
As you know on the defender 90 something was holding the fluid back,, so it was just drawing a little fluid through and lots of air bubbles around the nipple threads.
Same thing with my dads vw touareg. something holding the fluid back.. same as above.
on the 80 inch it worked quite well but i had to press the nipple in while sucking to stop air bubbles and turn the psi down so reduce suction.
on the cheapo skoda fabia with no abs it worked like a dream.
and on my austin rover mini it worked ok.
I used a gunsons easy pressure bleed thing once on the 80inch.. looked good but cap blew off master cylinder and sprayed everything with fluid.. it went in my eyes. Not keen on those anymore. 1953 80"
1987 mini city e
2011 90"
Post #418894 25th Apr 2015 10:46am
munch90
also with vac one you need a compressor to run it
the vac ones can use a lot of air and can be to much load for a home/hobby compressor
pressure ones don't need a compressor Thumbs Up
Post #418901 25th Apr 2015 11:00am
Anderzander
I have a 14cfm compressor - I would expect that to be enough ?
My concern with the pressure ones is them spraying fluid everywhere - something I expect couldn't happen on the vacuum type ?
Post #418908 25th Apr 2015 11:44am
