![]() | Home > Puma (Tdci) > bleeding / changing brake fluid |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
I use that Sealey pressure one.
It fast became one of my very favourite tools. Dont use it often mind, compared to spanners etc, but it sits there and I know it will make life nice and simple when I want to do any brake work! Brilliant bit of kit! Saves asking someone for help to ... one man job from now on! |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
What about the good old Gunson Eezlibleed, I have been using one for twenty five years and never had a problem bleeding or replacing fluid. Just remember to pump up the spare tyre afterwards.
For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
ezibleed have been about for years and years
never used one as use the more professional style ( no disrespect to users of them ) have heard of a few bottles cracking due to people over pressuring the bottles but if used within the instructions they should be ok , but prefer the breeders you can pump up manually |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Yeah,maximum of 20psi,but I use slightly less than that otherwise the seals leak,a bit of ptfe tape around the res cap as it always seems to leak there anorl.....but fer less than £20. Pov.spec,ftw. 2006, 110,TD5.
I use around 15psi with the Sealey!
Seems about right to me! |
