Home > Technical > Leaking Steering box - normal?
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
But of a rhetorical question in the title, I imagine the answer is that it's not normal for it to be leaking!
Noticed tonight when picking up the dogs frisbee off the drive that one of my steering links looked oily.
On further investigation it looks like the power steering box and drop arm are well coated in oil. It looks like something is leaking, maybe the shaft seal where the drop arm is? It's difficult to see from above (air filter box in the way)
Has anyone encountered this before? Is a bit of leakage normal?
There seem to be evidence of an oil mist on the axle casing too.
I wiped off some of the oil and it didn't seem to be leaking out with the engine off.
The reservoir is half full on the dip stick, first time I've checked it so I don't know how full it was before.
Oh it's a 64reg 90 SW with the grand milage of 2189! I've only had it since mid February
Post #416026 13th Apr 2015 8:45pm
munch90
No way does that look normal leakage being its only done that mileage
Post #416032 13th Apr 2015 9:06pm
It's a common fault but it is unacceptable! Get it sorted under warranty and if possible insist on a new steering box not a service exchange, ie reconditioned, box.
Post #416038 13th Apr 2015 9:47pm
alby
ho hum I thought as much, just didn't want it to be so.
I remember something about not holding the steering on full lock for long as it could cause the steering box or pump seals to fail or is it my imagination or an old wives tale?
It's not really done much tight manoeuvring, not while I've owned it anyway, and I don't think there's been any occasion when I've held the steering on full lock for a long period of time.
Not had a box fail before, an early defender I used to own I had the pump fail and dump all of the oil on the a1. All others have been fine.
cheers for the tip on new vs recon. Hadn't imagined that they might try and offer anything other than a new replacement, and I'll certainly be insisting on new especially since it's failed at an early stage.
I'll get in touch with a dealer tomorrow, probably Duckworth's at Market Rasen.
Post #416059 13th Apr 2015 11:13pm
alby
Just an update...
It's booked into the dealers on Monday.
They're going to have a look to diagnose it properly first, and then see what needs to be done. The warranty lady agreed with my request for a new box if it needed it due to it being a young vehicle.
For future knowledge, where is it they leak from generally?
Post #416114 14th Apr 2015 10:15am
Most commonly from the seal where the shaft carrying the drop-arm comes out the bottom, but I have also had them leak from the top cover.
it is unusual for a new box to leak so soon, and it suggests that either there is a defect with the box itself (or it hasn't been assembled very well), or it hasn't been assembled properly on the vehicle. If one of the pipe union seals is leaking, for example, it can undoubtedly simply be fixed. If the box itself is leaking, it shoudl be replaced.
My earlier comment about new not recon replacements is based on the experiences I had with my Disco 2, where the box developed a leak just before the warranty expired. LR would only fit a reconditioned box since these were the only parts available throught heir supply chain, and certainly at that time they were total rubbish. The first replacement sprang a leak within days, and when I investiaged you could see that the seal on the output shaft was crooked - totally skewiff! That box was replaced by another, which lasted a couple of months (and took me out of warranty) then started leaking from the top cover. In the end I bought a box of a breaked through Ebay, a box which hadn't been "reconditioned" by Landrover, and it has been fine to this day!
I think that the problem is that the boxes are reconditioned by a firm chosen for price, not quality, and definitely not by the original manufacturer, Adwest. If I needed a new box now for any Landrover, I would get it from Adwest, not Landrover.
Post #416117 14th Apr 2015 10:47am
alby
What a kerfuffle!
Many thanks for the info black wolf.
Well my little black defender has been at a main dealers since Monday, and they confirmed that the top cover is leaking on the steering box and we're going to source a replacement brand new steering box from Land Rover and fit it for me.
Have had a lovely discovery 4 SE in corris grey courtesy car from the dealers, it is simply awesome and I've grown very fond of it indeed.
However I've just heard from the dealers that sourcing a steering box has been a bit of a nightmare for them! The one they ordered up turned out to be LHD, so they ordered another one and that was LHD too. So they ordered a third one which they got them to open the box on before they sent it out to the dealers and that one was also LHD. Apparently there has been some sort of labelling error somewhere and within the constrictions of the official supply chain there are no RHD steering boxes available to them.
It apparently could be a week if not longer before they get their hands on one for me, so they've got Land Rover to organise a hire car for me in the meantime.
I'm off over to the dealers this afternoon to return their discovery and pick up the hire car, so will have a natter to them and see what is what.
Top notch service from the dealers, they have kept me informed all the way and have genuinely done their best, but I miss my little black defender Big Cry
I hope this isn't a sign of things to come though once production stops.
Post #418149 22nd Apr 2015 11:39am
dailysleaze
lol
I recently bought a Defender and was having the steering box replaced. It's a LHD and there was a delay because they got sent a RHD one by mistake Laughing
Post #418259 22nd Apr 2015 9:05pm
Stickleback
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Perhaps this issue is not as unusual as we'd all hope. I had similar problems with my 2014 a week or so ago.
Took it to dealers, expecting to be told what the problem was and to bring it back when the parts have arrived. However they diagnosed the problem to a leaking steering box, and told me that the vehicle should not be driven and should be left with them until fixed. Have to say I'd noticed a slight leak about 1,000 miles ago but couldn't be ar5ed to do anything about it , putting it down to character. The OP made me think again, especially as it was getting worse..
Dealers have given me a Freelander, which TBH (and don't want to upset Freelander owners here) just is not my cup of tea. It seems much bigger than my 110, i.e. much wider on the narrow moors roads where I live. Much harder to accurately place on the road. some of this may of course be down to it not being my car and not wanting to damage it...
Anyhow, I was told this Monday that the parts should arrive this Friday or next Tuesday - but now I'm not holding my breath as no doubt the wrong part will arrive.
Farnells at Bradford have been excellent throughout, not in any way their fault that the vehicle went wrong and bits are hard to source.
Good luck with getting your truck back on the road, and I hope they give you a decent loan car!
Post #418309 23rd Apr 2015 8:41am
alby
Lol daily sleaze. You best Look after that RHD box You've got as its rarer than unobtainium, rocking horse droppings, and unicorn tears. its even more rare than ******** EBAY RARE **********
Thanks stickleback, glad to know I'm not the only one affected.
Mine was wasn't leaking that badly tbh, I drove 160 miles up to the Lake District in the defender last weekend, I just stopped regularly to check the oil level on the way up and back and it used next to nowt. It used about 50ml that was all.
Yes I know what you mean about not wanting to scratch the loan car., not much moorland here in rural lincs but there are a fair few narrow lanes. The disco 4 feels massive compared to my 90, it feels enormously wide and long in comparison.
Land Rover were supposed to be ringing me yesterday afternoon to organise a hire car, but so far not a peep out of them, despite the dealership chasing them and pushing them.
I still have the loan disco from the dealership though so am mobile at least.
The frustating thing is, if the defender was out of warranty I wouldn't have thought twice about ordering up the part, and would have had it fitted long before now.
Post #418395 23rd Apr 2015 1:25pm
One thing to remember is that PAS fluid is very flammable, far more so than diesel. A hot manifold may be enough to cause ignition, so you really don't want it spraying around.
Post #418407 23rd Apr 2015 2:25pm
alby
Shocked hmm yes hadn't considered that tbh.
Fingers crossed Land Rover are sending a box out tomorrow so hopefully should have my defender back tomorrow afternoon. Hopefully this time it'll be the right one.
Post #418453 23rd Apr 2015 6:34pm
alby
Just had the dealers on the phone. Mine still not ready, still waiting for parts, will be mid next week now.
They have had another 14 reg defender come in today with a leaking steering box, and a third 14 reg one coming in on Monday with the same problem all with lowish miles.
Maybe a dodgy batch?
Despite mine being 64 reg, it actually went down the line in mid April last year.
Post #418738 24th Apr 2015 4:52pm
munch90
what is it with the later ones ?
p/s boxes
intercooler pipes
oil pumps
axles breaking
hub bolts breaking
rev hang
Post #418739 24th Apr 2015 4:59pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Cost reduction? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #418756 24th Apr 2015 6:13pm
