Home > Puma (Tdci) > Water leak into cabin - 90 XS |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
This not something I'm particularly worried about having had SIII Defenders in the past that leaked. Today the rain was quite bad here in S Wales and when I got home I spotted some water on the bare metal floor behind the front passenger seat. On looking carefully there were water drops on top of the folded rear seats, both sides and on the folded seat backs that faced the side sliding windows, also on the grey plastic "arm rest" on the cabin side beside the side windows.
The roof side window seal was dry as was the gutter below it. I can only surmise that the water was coming in through the base of the sliding window and being blown onto the seats as it was VERY wet and windy this am. Has anybody seen this and know of any cure? As this is a new vehicle under warranty should I return to the dealer or is this just something to live with. I know with previous Defenders leaks were fairly common but I've never had one like this and probably wouldn't have noticed it if I hadn't reached behind the front seat to get my Kindle ebook. Any advice much appreciated. |
1st Oct 2010 4:18pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
I had a 57 PUMA 90 XS. I got shot after 10 months due to the leaks. Under the rear carpet was almost always wet. It went back to the stealers 3 times to get fixed but falure everytime. I then had clear water coming out the dash when I went round a left hand bend. I got fed up when the clear water became a bit brown and rusty.
So got shot and found me a nice D3. So if you purchased a Cairns Blue 90 XS, black gen wingtop protectors and a Gen RAI and witness marks where they insisted I removed the A bar about 2 1/2 yrs ago from a dealer in Kent I really feel for you 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
1st Oct 2010 4:49pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
A new one shouldn't be leaking like that (even with today's weather). Take it to the dealers and get them to put it right for you. (Be persistant, it could well take them a number of attempts to find it). Peter
2008 SWB Truck Cab 1952 80" Soft top |
1st Oct 2010 5:07pm |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
It will take several attempts! Three in my case, two from the bulkhead area (dash removed twice) and one from the front door seals. Just found another under the offside small window next to the rear door. Poor seal between the tub and upper body leaving wet carpet and floor panel under the rear speaker. Might be worth other forum members checking this area as it is not normally noticable. Easy self fix, breaking out the silicone sealer at the weekend.
1st Oct 2010 5:57pm |
Thanks guys. This one is 6mts old. What I cannot understand is how the water got onto the folded rear seats yet the carpet, and under the carpet, below both side windows was dry!!!!!
1st Oct 2010 6:12pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
if it was windy it can get in between the sliding windows,check with a pressure washer,good luck 2.4 90 XS
2nd Oct 2010 7:52am |
Tried with a pressure washer and only got a few drops, a lot less than yesterday which wasn't a lot, by directing washer INTO the window ie: from the rear pointing forward. I have a thought though. This happened while I was driving from Tesco to home. Very wet/windy and I was driving with drivers window partly open ( NB: the water was on the passengers side rear seat ) BUT I have those Climair window deflectors fitted and they produce a slight -tve pressure in the cab with window open( cigarette smoke gets sucked out when window is partly open ) and all the rain/wind was onto the passenger side. Just a theory. I think I'll keep my camera in the car and take some photos if it happens again. This was the first time this has happened since I got my beloved Defender.
2nd Oct 2010 1:04pm |
adjust the stricker on the passenger to pull the door tighter on the seal 2.4 90 XS
2nd Oct 2010 1:42pm |
Sorry Grockle, I don't understand why that should work. The Front Passenger seat was dry. The water was on the rear passenger seat which was in it's folded position and the water was on the top surface and the side facing the sliding side window only.
2nd Oct 2010 3:00pm |
Alpine window pos source of leak then 2.4 90 XS
11th Oct 2010 1:00pm |
Well no response to full power from the washer. Have to wait for the rain again. Have camera handy in car for photos. Watch this space.
14th Oct 2010 11:11am |
