Home > Td5 > 2003 TD5 going up hill lost of power?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I found my 2003 TD5 has lost power while going up hill, even I lower the gear from 3 to 2(lower one gear even worst, look like need to pick up from the beginning...), full pedal gas, TD5 acceleration still no improve, been searching this might be the turbo wastegate or the MAF sensor, or both, really need some help here to figure put what happened!
The TD5 can go around 70+ mph on highway, but slow down when going up hill... Big Cry
Post #416296 15th Apr 2015 2:54am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Could be one of many things, try this to see if your wastegate is stuck....
Next thing to check is that you don't have a split intercooler hose, or one of the hoses might have blown or popped out?
Might be worth changing the fuel filter too if it's not been done recently, you can easily unplug the MAF sensor and go for a drive with it unplugged to see if it makes a difference, also, look at the wiring harness, check the red connector under the seat that goes into the ecu, if there's oil in the loom it might just need cleaning with brake cleaner.
Best of luck
Post #416304 15th Apr 2015 5:17am
RF3777
Hi, Lambley, actually what does this push do to the wastegate?
does it release something?
Where is the intercooler hose located? Neutral
Post #416348 15th Apr 2015 9:26am
Lambley
If you look at the turbo, you will see a rod coming over the top and connecting to an arm. This is the rod that actuates the wastegate, you should be able to move this part (towards the bulkhead - you'll need to grip it with some pliers or mole grips to move it). You will feel some resistance, this is normal but it should move reasonable freely.
If it doesn't move freely, then the wastegate will not be working correctly. Try spraying it with WD40 or GT85 maintenance spray if it feels stiff. It's pretty common for them to seize up and quite often they can be free'd off with a bit of trying (and a fair bit of WD40).
The intercooler hoses come from the intercooler, which is located behind the grill, it looks like this... maybe not as shiny or as large but it'll be the same...
The hoses coming from it will look something like this...
They are arranged like this...
One of the hoses might have come off, or the clamps sometimes work loose, they might be greasy inside, so the ends sometimes slip off under boost, check that there's no loose clips or hoses that have come off, if they have, then clean up any greasy ends and re-clip them back on. There might even be a split hose, just give them a check over.
If you pay for my return plane ticket to HK I'll come and sort it for you, I'll give your Landy a full valet too Rolling with laughter
Post #416364 15th Apr 2015 10:34am
shaggydog
Beat Me to it Lambley Laughing
I was in Hong Kong for CNY Visiting my Girlfriends Dad and could have had a look over it then - naturally was probably working fine then Rolling Eyes
Your not this one are you?
 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #416366 15th Apr 2015 10:47am
JWL
I get those symptoms every 10K miles or so and had the last episode on the Easter weekend going to Convoy 4 Heroes. It was doing it on every uphill when towing my Sankey and again on the Saturday having a drive round locally. I pulled the pump out of the tank and with the action of draining it and just generally being disturbed must have shifted whatever crud was in it as it's been perfectly fine ever since.
Post #416378 15th Apr 2015 11:37am
RF3777
Let me take a look of those thing, hope I can sort it out soon!
But how many play the wastegate rod should go?
Come to HK I buy you a beer... Thumbs Up
Post #416539 16th Apr 2015 5:02am
RF3777
I think my Defender was from the same age, but mine doesn't have the snorkel, Gray in color, HK is now importing the Ultimate edition defender, Price as high as HK$ 620,000.00 Bow down
BTW, that street is full of table dance... Whistle
Post #416540 16th Apr 2015 5:05am
shaggydog
Haha yes my Girlfriend was taking me to meet one of her friends from school and I noticed things were getting a bit.....Interesting. I pointed it out to her and she just laughed and said yea unfortunately there are a lot of "performers" in this area. I just thought they were being friendly Rolling Eyes
Hope I haven't got anyone in the Hong Kong Land Rover Club in trouble Laughing
Great city otherwise, definitely going back at some point in the future Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416570 16th Apr 2015 8:27am
Lambley
Any progress FF3777?
Did you manage to find anything?
Do I need to book flights?!
Post #416779 17th Apr 2015 6:30am
RF3777
Mr. Green
I'm not able to check it yet, need some work out of H.K., can only be check the coming Saturday!
I think I'm going to buy a can of MAF sensor cleaner first and ready! Bow down
BTW...I need some instruction for install a new radio bezel, the last owner broke that thing while changing the antenna??
dont know how that related??
Can I just use something with 4 point insert the OEM radio and pull it out, then simply change the bezel...or its much more complicated? Neutral
I have order the new Bezel and retention wire, clips from UK, very expensive...with postage!
(what does that retention wire do??? use to hold up the whole radio weight??)
anyone would have some tips for that job?
Bow down
Post #417172 19th Apr 2015 6:07am
RF3777
Update...I did unplug the MAF sensor and took a hilly ride today!
WOW...the power is back, so the problem is replace a new MAF sensor,
I believed the power will be more with new sensor, since the ECU only reading the air flow in a flat rate!
Rolling Eyes
Post #420832 3rd May 2015 9:42am
mk1collector
With cleaning that amount of oil out of the ecu I'd say that is where your power came back Ray
My build thread
Post #420838 3rd May 2015 10:07am
RF3777
Not really...I did clean the oil (ECU) in the morning, then took a 50km ride on speedway and hilly, nothing change, no power...
worst when I lower one gear just as before, but the ride unplug the MAF sensor was really different, power is back! Mr. Green
Post #420853 3rd May 2015 11:17am
RF3777
Change a new part today, the MAF sensor,
the TD5 go quieter, smoother, less gear changes! Mr. Green
Post #422013 8th May 2015 12:36pm
