![]() | Home > Td5 > 2003 TD5 going up hill lost of power? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
I found my 2003 TD5 has lost power while going up hill, even I lower the gear from 3 to 2(lower one gear even worst, look like need to pick up from the beginning...), full pedal gas, TD5 acceleration still no improve, been searching this might be the turbo wastegate or the MAF sensor, or both, really need some help here to figure put what happened!
The TD5 can go around 70+ mph on highway, but slow down when going up hill... ![]() |
Hi, Lambley, actually what does this push do to the wastegate?
does it release something? Where is the intercooler hose located? ![]() |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
If you look at the turbo, you will see a rod coming over the top and connecting to an arm. This is the rod that actuates the wastegate, you should be able to move this part (towards the bulkhead - you'll need to grip it with some pliers or mole grips to move it). You will feel some resistance, this is normal but it should move reasonable freely.
If it doesn't move freely, then the wastegate will not be working correctly. Try spraying it with WD40 or GT85 maintenance spray if it feels stiff. It's pretty common for them to seize up and quite often they can be free'd off with a bit of trying (and a fair bit of WD40). The intercooler hoses come from the intercooler, which is located behind the grill, it looks like this... maybe not as shiny or as large but it'll be the same... ![]() Click image to enlarge The hoses coming from it will look something like this... ![]() They are arranged like this... ![]() One of the hoses might have come off, or the clamps sometimes work loose, they might be greasy inside, so the ends sometimes slip off under boost, check that there's no loose clips or hoses that have come off, if they have, then clean up any greasy ends and re-clip them back on. There might even be a split hose, just give them a check over. If you pay for my return plane ticket to HK I'll come and sort it for you, I'll give your Landy a full valet too ![]() |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Beat Me to it Lambley ![]() I was in Hong Kong for CNY Visiting my Girlfriends Dad and could have had a look over it then - naturally was probably working fine then ![]() Your not this one are you? ![]() Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
I get those symptoms every 10K miles or so and had the last episode on the Easter weekend going to Convoy 4 Heroes. It was doing it on every uphill when towing my Sankey and again on the Saturday having a drive round locally. I pulled the pump out of the tank and with the action of draining it and just generally being disturbed must have shifted whatever crud was in it as it's been perfectly fine ever since.
Let me take a look of those thing, hope I can sort it out soon! But how many play the wastegate rod should go? Come to HK I buy you a beer... ![]() |
I think my Defender was from the same age, but mine doesn't have the snorkel, Gray in color, HK is now importing the Ultimate edition defender, Price as high as HK$ 620,000.00 ![]() BTW, that street is full of table dance... ![]() |
Haha yes my Girlfriend was taking me to meet one of her friends from school and I noticed things were getting a bit.....Interesting. I pointed it out to her and she just laughed and said yea unfortunately there are a lot of "performers" in this area. I just thought they were being friendly ![]() Hope I haven't got anyone in the Hong Kong Land Rover Club in trouble ![]() Great city otherwise, definitely going back at some point in the future ![]() Self confessed mileage hunter ![]() |
Any progress FF3777?
Did you manage to find anything? Do I need to book flights?! |
![]() I'm not able to check it yet, need some work out of H.K., can only be check the coming Saturday! I think I'm going to buy a can of MAF sensor cleaner first and ready! ![]() BTW...I need some instruction for install a new radio bezel, the last owner broke that thing while changing the antenna?? dont know how that related?? Can I just use something with 4 point insert the OEM radio and pull it out, then simply change the bezel...or its much more complicated? ![]() I have order the new Bezel and retention wire, clips from UK, very expensive...with postage! (what does that retention wire do??? use to hold up the whole radio weight??) anyone would have some tips for that job? ![]() |
Update...I did unplug the MAF sensor and took a hilly ride today!
WOW...the power is back, so the problem is replace a new MAF sensor, I believed the power will be more with new sensor, since the ECU only reading the air flow in a flat rate! ![]() |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
With cleaning that amount of oil out of the ecu I'd say that is where your power came back Ray
Not really...I did clean the oil (ECU) in the morning, then took a 50km ride on speedway and hilly, nothing change, no power...
worst when I lower one gear just as before, but the ride unplug the MAF sensor was really different, power is back! ![]() |
Change a new part today, the MAF sensor,
the TD5 go quieter, smoother, less gear changes! ![]() ![]() ![]() |
