Home > Maintenance & Modifications > Terrafirma 50mm lift kit
Crispin
Hi Guys.
Again, sorry if this topic has been covered. Can one search for covered topics without having to go through page by page? Just a quick vote really. Is it any good? Pros and cons. Thanks.
Post #416179 14th Apr 2015 4:05pm
Crispin
The lift will be primarily to accommodate my 285/75R16s which I know will fit to standard suspension but to me doesn't leave much room for anything else. I do take it offroad but not through anything major, mostly greenlaning. Does anyone have an opinion on the 50mm spring spacers which of course will utilise the original springs and shocks but will provide 50mm of lift. Cheers guys.
Post #416182 14th Apr 2015 4:22pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
Honest opinion...... Don't do it. The suspension I've had from terrafirma has been very poor quality. Leave it at standard height , your 285s will fit, or go 265. I hated every mile of driving mine while I had it lifted. Never again, but each to their own.
Post #416234 14th Apr 2015 7:24pm
landy andy
Terrafirma = poo.
Sorry
Andy
Post #416257 14th Apr 2015 8:24pm
Crispin
I was under that impression Andy. I wonder why they still sell them if they're that bad? OMEs are probably a better option but I'm going to run with the standard setup and see how it goes. Thanks.
Post #416388 15th Apr 2015 12:45pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
I'll pick up my jacket and shut the door behind me! Big Cry
Me and my 2" Terrafirma Lift Kit...... Big Cry Big Cry Big Cry
On the plus side.... there's another item for the "Mod required" list. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #416395 15th Apr 2015 1:48pm
shaggydog
I used to run on Bearmach Blue +2" springs and Procomp Shocks.
Was very comfortable when fully laden but the rest of the time was a bit crashy. Having said that in the months before I took it off it had settled down quite nicely so may have been a case of bedding the springs in a bit?
I took them off in the end as the nature of my work changed and I no longer needed the lift.
The rear springs need a bit of a repaint but the shocks and fronts are still in good used condition if your interested?
However if your already thinking of sticking standard I would as it caused me difficulty with parking and when empty it was noticeably more uncomfortable Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #416414 15th Apr 2015 2:55pm
Crispin
Thanks Shaggydog. I'm going to give it a whirl on the standard ride height and see how it goes. What I would really like is just to lift the front by an inch or so to match the rear. I know it'll look odd if I load the back up but it doesn't happen very often. The rear height is fine for the 285s, it's just the front that could do with an inch. Any ideas?
Post #416428 15th Apr 2015 3:43pm
shaggydog
If it doesn't already have them try fitting some spring isolators to the top. Won't quite be an inch but will make a bit of a difference and should give a (very) slightly quieter and smoother ride.
Don't fit them top and bottom though as this will allow your spring to unseat itself at the bottom which is not good! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416431 15th Apr 2015 3:54pm
mk1collector
I fitted them top and bottom with the spring plates bolted to the bottom so they can't come off. Ray
My build thread
Post #416442 15th Apr 2015 4:31pm
shaggydog
Would be interested to hear more about the spring plates, didn't think you could fit them to the front? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416460 15th Apr 2015 6:01pm
mk1collector
Like these, they hold the bottom of the spring down.
http://www.ebay.co.uk/itm/TERRAFIRMA-TF505...2a2e5d7411 Ray
My build thread
Post #416485 15th Apr 2015 6:57pm
shaggydog
Fantastic Ray thank you for that Very Happy
Will get a pair on order Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416487 15th Apr 2015 7:05pm
mk1collector
Those are for the front to go around the shocker and you can get rear ones that are straight because the shock is not through the spring Ray
My build thread
Post #416489 15th Apr 2015 7:13pm
shaggydog
I have rear ones fitted as standard but the front ones didn't have any so this should allow me to refit my front ones Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #416502 15th Apr 2015 7:56pm
