Home > Puma (Tdci) > A new rattle... **SOLVED** |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
Try the rear mud shield on the propshaft. Puma 110" SW ............................................................. Earth first. Other planets later |
4th Jun 2010 12:18am |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Am I just being dim or am I missing something, can't find anything shield related anywhere near the prop...
4th Jun 2010 5:12pm |
herbie Member Since: 27 Sep 2010 Location: West Sussex Posts: 1 |
Hi Warren
I have the same problem (hence joining the forum) The rattle from the rear !! Did you find out what the problem is please? Many thanks Herbie |
27th Sep 2010 9:13am |
Hi, I should have put a reply on the forum when I got it sussed... whoops.
But it turned out to be the roll pin in the rear diff that had worked itself loose. |
27th Sep 2010 9:52am |
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 |
Would be good to add *SOLVED* to the thread title. Saves time for many.
27th Sep 2010 12:36pm |
27th Sep 2010 1:21pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Hi,
What is the roll pin in the rear diff and how did you find this out? |
28th Sep 2010 7:51am |
Well, I could be wrong so feel free to correct me, but I beleive it locates the pinion gear, and because the pin is harder than the casing it fits into it wears the hole & makes it bigger... Although I could be wrong.
I went for a drive with a mechanic from the dealers who knew exactly what it was right away. I have a picture of an older diff that blew on my old 90 somewhere, that shows the roll pin.. I'll see if I can dig it out when I get home. |
28th Sep 2010 9:42am |
