Home > Puma (Tdci) > Clunk when driving off
Naks
Hi all
Both SWAMBO & I have noticed a new noise when driving around yesterday - a soft but distinct 'clunk' when driving off.
When we got home SWAMBO walked along the car while I tried to replicate it. It occurs almost every time I drive off from standstill in 1st gear, and SWAMBO says it sounds like it's coming from 'under the seats' - which probably means the transfer case.
What could it be? Confused
Post #41373 27th Sep 2010 8:33am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mine does this, think it was MK who helped me suss out where it was coming from in another post...
The prop will turn freely and then suddenly 'snatch' and take up drive. Mine also does it occasionally in higher gears.
Post #41378 27th Sep 2010 9:49am
Naks
Mkay, is this normal, or will it get progressively worse and then the propshaft ends up stuffing the transfer case and/or rear diff?
Post #41379 27th Sep 2010 9:50am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I'm not sure if its the same problem i had.... but when i took mine in to LR they used lock tight on the flange on the rear prop where it meats the rear diff and ever since i'v had no problems.... there is a tec bulletin on it so they know about it Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41383 27th Sep 2010 10:19am
MK
lift the front axle and by hand turn the front output shaft: it should has a little backlash (like 5�). Do it with the unlocked TCase. Do the same with the rear output shaft.
Also check the the free play on both propshafts&diffs, in such case it should be around 45�. Apparently anything beyond those numbers will produce a clunk.
I found out that when the clutch plate assy starts to go wrong then it causes all kind of noises on the driveline. Puma 110" SW
Post #41385 27th Sep 2010 10:31am
K9F
Mine too....they needed it for an extra 24 hours curing/drying time for the Loctite! Thumbs Up
Once done didn't return! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41404 27th Sep 2010 4:50pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I put mine into the dealer to have it attended to and they changed to roll bar rubbers. Driving away from their workshop the clunk was still there!
Where does the Loctite go? And what grade is best?
Many thanks,
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #41437 28th Sep 2010 12:22am
K9F
Austen,
I'm not sure exactly what and where but there is definately a tech bulletin about it, a quick call to your dealer and they should be able to point you in the right direction!
Loctite 271 would be my personal 'weapon of choice' as it has a 'strong' strength rating for larger applications and fasteners up to 1" If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41439 28th Sep 2010 6:17am
austen
Thanks K9F.
Austen Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #41441 28th Sep 2010 6:29am
K9F
No need for thanks, but you're welcome Matey! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41444 28th Sep 2010 8:02am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 110 had the same issue. The first garage I brought it to said that they'd sort it... and didn't.
The next lot did sort it, but ended up replacing a few parts because they'd worn prematurely due to all the clunking and clanging.
Post #41445 28th Sep 2010 8:11am
AndrewS
Check the 4 bolts/nuts on the front of the rear propshaft 130's have feeling's as well you know Smile
Post #41446 28th Sep 2010 8:20am
CapeLandy
South Africa
Post #41455 28th Sep 2010 10:52am
Naks
CapeLandy wrote:
Check this extract from the manual
http://www.defender2.net/forum/topic3431.html?highlight=locktight
thanks guys , I'll just take it to Schalk if it's something simple. Thumbs Up
Post #41470 28th Sep 2010 12:58pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
..... I did hear from a mech who was asked to fix a �clunk� in a car that occurred when pulling away and when breaking � short fix as he removed the bowling ball from the boot� Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #41541 29th Sep 2010 11:32am
