![]() | Home > Puma (Tdci) > Clunk when driving off |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Hi all
Both SWAMBO & I have noticed a new noise when driving around yesterday - a soft but distinct 'clunk' when driving off. When we got home SWAMBO walked along the car while I tried to replicate it. It occurs almost every time I drive off from standstill in 1st gear, and SWAMBO says it sounds like it's coming from 'under the seats' - which probably means the transfer case. What could it be? ![]() |
Mkay, is this normal, or will it get progressively worse and then the propshaft ends up stuffing the transfer case and/or rear diff? |
I'm not sure if its the same problem i had.... but when i took mine in to LR they used lock tight on the flange on the rear prop where it meats the rear diff and ever since i'v had no problems.... there is a tec bulletin on it so they know about it
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
lift the front axle and by hand turn the front output shaft: it should has a little backlash (like 5º). Do it with the unlocked TCase. Do the same with the rear output shaft.
Also check the the free play on both propshafts&diffs, in such case it should be around 45º. Apparently anything beyond those numbers will produce a clunk. I found out that when the clutch plate assy starts to go wrong then it causes all kind of noises on the driveline. Puma 110" SW ............................................................. Earth first. Other planets later |
Mine too....they needed it for an extra 24 hours curing/drying time for the Loctite! ![]() Once done didn't return! ![]() Treat every day as if it is your last....one day you will be right!! |
austen Member Since: 10 Mar 2008 Location: Sydney Posts: 52 ![]() ![]() ![]() |
I put mine into the dealer to have it attended to and they changed to roll bar rubbers. Driving away from their workshop the clunk was still there!
Where does the Loctite go? And what grade is best? Many thanks, Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
Austen, I'm not sure exactly what and where but there is definately a tech bulletin about it, a quick call to your dealer and they should be able to point you in the right direction! Loctite 271 would be my personal 'weapon of choice' as it has a 'strong' strength rating for larger applications and fasteners up to 1" If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks K9F.
Austen Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
No need for thanks, but you're welcome Matey!
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
My 110 had the same issue. The first garage I brought it to said that they'd sort it... and didn't.
The next lot did sort it, but ended up replacing a few parts because they'd worn prematurely due to all the clunking and clanging. |
Check the 4 bolts/nuts on the front of the rear propshaft 130's have feeling's as well you know
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Check this extract from the manual
http://www.defender2.net/forum/topic3431.html?highlight=locktight |
thanks guys , I'll just take it to Schalk if it's something simple. ![]() |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 ![]() ![]() ![]() |
..... I did hear from a mech who was asked to fix a ‘clunk’ in a car that occurred when pulling away and when breaking – short fix as he removed the bowling ball from the boot…
![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
