Home > Puma (Tdci) > Rear door
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Rear door
Hi guys, the rear door in the top left corner is letting in water Big Cry if I loosen the bolts is there plenty of movement to adjust the door and close the gap as it is quite a considerable opening, the seal is good and no nicks or cuts, the door is just touching it when closed and not compressing the joint, thanks in advance. Cogito ergo sum
Post #413889 5th Apr 2015 8:23am
K9F
Safari Door???? There is a little adjustment. Take the spare off first. The bolts are not captive so you will have to remove any trim and slacken them off. It'll be a two person job. The lowest nuts are accessible through the rear arch.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413893 5th Apr 2015 8:33am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
I had same with mine I adjusted the catch plate and that cured it Thumbs Up
Post #413894 5th Apr 2015 8:38am
Paul55
Thanks for the prompt reply K9, I thought that would be the case, I shall give it a go this morning Thumbs Up Cogito ergo sum
Post #413895 5th Apr 2015 8:38am
Paul55
I'll give the catch plate a tighten as well, forgot about that Thumbs Up Cogito ergo sum
Post #413896 5th Apr 2015 8:40am
