Home > Puma (Tdci) > Rear door |
Safari Door???? There is a little adjustment. Take the spare off first. The bolts are not captive so you will have to remove any trim and slacken them off. It'll be a two person job. The lowest nuts are accessible through the rear arch.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
5th Apr 2015 8:33am |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
I had same with mine I adjusted the catch plate and that cured it
5th Apr 2015 8:38am |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 511 |
Thanks for the prompt reply K9, I thought that would be the case, I shall give it a go this morning Cogito ergo sum
I'll give the catch plate a tighten as well, forgot about that Cogito ergo sum
5th Apr 2015 8:40am |
