Home > Technical > Webasto Airtop 2000s
Page 4 of 5 <12345>
Les Brock
Stand by for a burning smell,
Closley followed by.......
Jo - "where's the Fire putter outer" Rolling with laughter
Post #353128 22nd Aug 2014 1:53pm
walfy
I knew a grown up would ask another grown up on my behalf. Bow down Bow down Bow down
Didn't think of becoming a veh fitter for the afternoon and asking. Rolling with laughter
So when we ran it up on the bench the other day we had it correct. Happy days. Now to purchase a stepped hole cutter and drill some holes Shocked 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #353129 22nd Aug 2014 1:53pm
walfy
Thanks Les!!! That is why when I run out of knowledge/capability I'm not frightened to ask for help. Save big bills later on down the line.
Just need to source some carling switches now and we're away.
I can feel a decent order to MUD UK is in order 110 D250 SE HT
110 USW SOLD
Post #353130 22nd Aug 2014 1:55pm
Mark.... I've got that electricians hole cutting kit at home, various sizes, before you go buy anything.
think I've got a few carling switched kicking around too. ex project90-3. Thumbs Up
(that could work well... If they're in my garage I can tie some string together all ready loomed up and neat. Relays etc.
Post #353132 22nd Aug 2014 2:11pm
walfy
I need to template the hole and fit the rotary switch. This will determine the amount of carlings I can fit. Want to fit the max possible to future proof the system. I reckon 4 will be the magic number. I have 1 so will need to purchase 3 and the surrounds. If 3 is the magic number then I can just buy the 3 switch mount and make it easy for myself. 110 D250 SE HT
110 USW SOLD
Post #353137 22nd Aug 2014 2:39pm
walfy
I now have all the bits and bobs I need for my installation. Looking at now mounting the heater unit but it looks very close the underside of the seat.
Has everyone mounted theirs so that the outlet points forward to the front of the vehicle or have they mounted it sideways across the vehicle? 110 D250 SE HT
110 USW SOLD
Post #355685 4th Sep 2014 6:57pm
Rob1769
Eberspacher / or... (webasto ) Project Toasty
Hi Guys, a few photos of my Eberspacher install, its in a series though but would be the same in a Defender.. works for me! its boiling...
Well, I urmmmed.. n aggghed.... but eventually succumbed & its bought - fitted & Bloody HOT!!
Mounted Controller next to my LPG Changeover Switch
Vents Nicely Cut out & Fitted
Ducting In & sealed with 70mm rubber Grommets
Heater Tucked Nicely under Passenger Seat & Return Air Intake Duct routed 'Out & Back In Again' all Sealed and grometted !
Seeing as LR is Petrol & LPG had to have a ally fuel tank fabbed up as Heater is Diesel -- as I didn't fancy the idea of a petrol heater under the seat ( I know they are safe but I'm a Tart)!
'Tunderneath Bits'
Exhaust Outlet
TOASTY !!!! in Excess !!!!!
Post #360736 28th Sep 2014 11:16am
walfy
Looks good. My project has gone on hold for a while. As something more important has cropped up and can't be put off. Seems I have a few projects on the go at the moment. Can't wait to get the Webasto fitted though. Ready for some winter camping 110 D250 SE HT
110 USW SOLD
Post #360738 28th Sep 2014 11:20am
VeeTee
Netherlands
@Rob1769, Neat install! Bow down Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #360781 28th Sep 2014 2:48pm
jst
nice install. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #360934 29th Sep 2014 9:35am
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
what about the system like on the discovery that heats the coolant and then blows thro the vehicles vents is this an option to fit on a Defender ?
Post #360936 29th Sep 2014 9:41am
jst
yes it is, but bulk of heat goes into coolant and lump warming you then rely on LR heater box to transfer heat to cabin.
i had a thermo Top C in my td5 for warming the lump (primarily) and then the interior as a 2nd priority.
my puma has airtop for cabin heat and thermo top to warm the lump. run both on a school day in the winter. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #360937 29th Sep 2014 9:44am
walfy
Right, my project is back on. Plus I have a deadline. We are going away in the near future and the Mrs wants heat in the rooftent. So I need to get on with it.
To that end does anyone have detailed pics of where you have mounted the Webasto unit. Managed to crawl underneath today and find roughly where it needs to go but there are a lot of brackets and other bits and bobs in the way.
I have 2 places in mind but not sure which is the easiest solution. What is the considered opinion of those who have fitted theirs already?
 110 D250 SE HT
110 USW SOLD
Post #408362 17th Mar 2015 11:38am
JWL
I know mines a Eberspacher D1 but they're roughly the same size and I've mounted mine in the same point as your top picture. Have a study underneath first so you work out where the strengthening ribs are for the seat box and you'll find a point where you don't have to disturb any of them plus you can get the intake and exhaust pipes out tidy. mine draws the air from by the door and blows hot air forward through a 90' bend so hot air goes towards the front of the cabin.
Just looked again and mine is under the near side seat as the framework of the centre seat takes up too much room. the exhaust is routed and ends inbetween the back wheel and the rear passenger door and the air intake draws air from just under the floor of the rear bed directly above the propshaft. I have done some pretty deep wading, been door sill deep in gloopy mud and have never had a problem in the past 4 years it's been fitted.
I do use a seperate fuel tank on mine for a couple of reasons, one was that I didn't want to draw on the main tank on my Td5 and secondly it's far cheaper to run the heater on cherry.
Post #408366 17th Mar 2015 11:52am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi Walfy,
I've put mine sideways, with a +/- 90° bend at the exhaust side made from some tubing.
This way I can still determine where to direct the hot air.
In case you put something large in front of the second row seats, the exhaust would be blocked if the heater blows directly to the front. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #408367 17th Mar 2015 11:54am
Page 4 of 5 <12345>
