![]() | Home > Technical > Webasto Airtop 2000s |
This may be of no use to you at all but on my Eberspacher I put a timer into the circuit but there wasn't enough power in the loom to power the timer and the rest of the loom so I put the timer on it's own power circuit and used it to trigger a standard relay which switches the heater on and off as necessary so it acts just as a remote on off switch.
