Home > Tdi > Discovery LT77S ?
Page 2 of 2 <12
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
shaggydog wrote:
Be careful though as not all disco boxes have diff lock which would leave you with a serious disadvantage.
Yeah for now i mite stay with this box Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #408113 16th Mar 2015 4:09pm
Mountain_man
Wales
All tdi discovery transfer boxes are 1:2 and have difflock. You only need worry about losing difflock if you get a transfer box from a TD5 Disco. I have a disco box in my 110 running 235/85 tyrres and I would never change it for a 1.4. I do a lot of towing too. I have no problem using low box to pull away on very steep hills with very heavy loads and changing to Hi-range on the fly and towing in 4th is actually better for the gearbox than in fifth. Mind you, my 110 is tweaked a little so it does go pretty well.
Post #408137 16th Mar 2015 4:55pm
cornish rattler
[quote="shaggydog"]What you doing with the old one? Whistle[/quote
Mite sound a daft way of do this but if i can find out if both the disco 200 and defender 200 cylinder heads are the same i mite look for a disco 200 engine, drop it in the 90 as a defender engine, re build the defender engine and fit it as a disco engine when we get round to doing the chassis swap.
i have got to do it this way as the 90 has to stay on the road give or take a couple of days for swapping everything over and stuff Smile Graham
Post #408173 16th Mar 2015 5:40pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
I was looking for a little more top end, do not tow much. Road are straight and fast round here.
Post #408178 16th Mar 2015 5:48pm
shaggydog
The heads are the same but the bell housings are different, the turbo positions and therefore front of exhausts are different and the plumbing at the front is different.
I can totally understand your motivations to do so as I too need mine every day so every day off the road is a major issue but it may be worth for the sake of the amount of hassle paying extra for the Defender 200 as it will make the swap over much cheaper and easier, plus if you rebuild them both you will get a much better price for a genuine defender 200 than discovery. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #408242 16th Mar 2015 8:24pm
cornish rattler
Yeah tbh i would rather rebuild the disco engine and then fit it to my truck as i don't really like the defender engine ( looks ) but i can't afford to have my son travelling all over the show with a tired engine so the soon i get a tempory engine the better, i know they both have there good points and bad points but i just prefer the disco look Smile Graham
Post #408253 16th Mar 2015 8:52pm
steventheplumber
Parts for defender 200tdi are getting hard to find. Was offered £1000 for my engine the other day. But then would have to find a replacement Laughing
Post #408268 16th Mar 2015 9:26pm
cornish rattler
Yeah thats what i am a bit worried about Big Cry Graham
Post #408294 16th Mar 2015 10:43pm
shaggydog
Some bits are however I have never had any difficulty finding parts for it?
Most parts are still available from Land Rover, you just have to accept they are expensive but then again any classic car is.
To be honest what is there to replace it with? Very few simple TDi engines around now as they all have some form of electronics or are too small. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #408346 17th Mar 2015 9:42am
steventheplumber
Found turbo hard to find. Had two sent out wrong even though I sent them pictures
Post #408380 17th Mar 2015 1:04pm
cornish rattler
Yeah i think its more external parts that are getting thin on the ground really aspecially defender 200 stand a bit more of a chance with disco 200 bits i think Smile Graham
Post #408586 18th Mar 2015 12:15am
steventheplumber
Yes think I will update the engine when my pockets are deep enough, but for now running OK. Part from no power steering this week, feel like Popeye Rolling Eyes
Post #408601 18th Mar 2015 8:08am
Page 2 of 2 <12
