![]() | Home > Tdi > Discovery LT77S ? |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1593 ![]() ![]() ![]() |
Yes it will fit but you will need to change the bell housing.
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Possibly the handbrake linkage
It will fit but you will have to convert over the gear stick linkages as the Discovery's have a short stick and the Defenders have long sticks and the bellhousings are different.
To be honest I don't see any real benefit unless your old box is pre-Lt77 or badly warn? What do you have fitted currently? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Hi shaggydog, yeah atm its fitted with the defender LT77 box, as reguards any benifit i was thinking gearing
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Same gearing so no difference.
![]() Self confessed mileage hunter ![]() |
What transfer box do you have?
Are right ok ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
There is no sticker or s/n on my tranny box but going off the way it drives i think its a 1.4 tranny box ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
If you changed the transfer box to a Discovery 1.2 box then you would get a slightly longer legged Tdi but would suffer when heavily loaded.
That said, this does seem to effect 110's more than 90's anyway so you should be ok being as yours is lighter to begin with ![]() Self confessed mileage hunter ![]() |
Ditto above, chap is going to do my one for me £150 fitted if my tfer box OK my box part ex
Be careful though as not all disco boxes have diff lock which would leave you with a serious disadvantage. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Yeah something to look at once i have decided what i am doing with the engine ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
What you doing with the old one?
That's a thought will check that!
