Home > Maintenance & Modifications > Hazard switch problem
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
My hazard switch will switch between the on and off position normally. However in the On position the lights do not flash, but when I push the switch in a fraction they operate normally and stop again when I release.
New switch required ?
Thanks
Gavin
Post #407457 14th Mar 2015 10:22am
Terryt
Drop the switch out mate had that issue the block at the back had worked lose.
Terry
Post #407462 14th Mar 2015 10:53am
They do jamb in the housing as well, especially if the centre panel has been painted, a little Vaseline around the edge will help
Post #407473 14th Mar 2015 11:48am
gavinpm
Thanks gents.
Terry what exactly do you mean by 'drop the switch out' - I was under the impression that I would have to remove the dash. If there is an alternative to removing the dash I would be happy with that.
Thanks
Gavin
Post #407491 14th Mar 2015 12:20pm
