![]() | Home > Maintenance & Modifications > Hazard switch problem |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
Drop the switch out mate had that issue the block at the back had worked lose.
Terry |
They do jamb in the housing as well, especially if the centre panel has been painted, a little Vaseline around the edge will help
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Thanks gents.
Terry what exactly do you mean by 'drop the switch out' - I was under the impression that I would have to remove the dash. If there is an alternative to removing the dash I would be happy with that. Thanks Gavin |
