Home > Puma (Tdci) > Low range indicator
grafty99
Low range indicator
Evening all. I noticed today that under the Rev counter on my 2.2 there is a low range symbol the same as most of the landrover range (should illuminate green I believe) so I slipped it into low range but it didn't light up. Probably shouldn't anyway but would be cool if it did/should but doesn't is that how it is? I'm guessing so Sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #407092 12th Mar 2015 10:33pm
No, it is a left-over from the original application of the IPAC (Disco 3) and is not used on Defender.
Post #407095 12th Mar 2015 10:39pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
Although its function is mentioned in the 2.4 puma owners manual,it's not working..
The hi-low switch is on the transfer case,the black wire(mentioned in the workshop manual) is present on the instrument cluster plug,out of curiocity i took out the cluster and part-dismandled it and found out that there is a led missing on that spot,i hoped it would be an old-style bulb missing but soldering isn't my best talent..
Post #407125 13th Mar 2015 6:19am
jst
the very early Pumas had the function enabled, we had quite a few launch vehicles that illuminated the low indicator when low was selected
i guess they dropped it reckoning that the avg defender drive could work out it was in low when at 45mph and 4000rpm. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #407131 13th Mar 2015 7:12am
grafty99
So if. The wiring is present to the ipac then soldering in a green 5050 led might make it functional? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #407135 13th Mar 2015 7:37am
fatman
But you must first remove the cluster transparent cover then the instruments' needles,the back facia with the graphics(rpm-mph etc) split the rest of the cluster case and then just solder a led,easyyyy Laughing Laughing
I thing Land Rover "forgot" this led on purpose,then they had to make warranty recalls for the transfer case hi-lo switch-top quallity,it's better not to have a low range indicator at all than to have it work intermintently Laughing Laughing
Post #407160 13th Mar 2015 8:42am
munch90
There is no hi lo switch on the gearbox as far as I know . So not a lot of point mucking around with the dash part
Also why bother worrying about it when you can see lever position ( unlike diff lock ) and it's easy to tell as soon as you pull away
Post #407164 13th Mar 2015 8:47am
fatman
On my transfer case there are 2 switches,the usual one for difflock(over the front output flange) and higher up on the transfer case(where the hi-lo cable-rod is connected),the hi-lo switch Confused
Post #407176 13th Mar 2015 9:18am
Don't for goodness sake mess with it if there is nothing wrong with it in the first place. Laughing
If you do you'll propbbaly then end up with a problem for your efforts.
Post #407189 13th Mar 2015 10:02am
K9F
Hope Caterham doesn't see this thread. Shocked Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407192 13th Mar 2015 10:08am
There is a high/low switch on the transfer box, which is used to tell the ECM which throttle response map to use.
I think that LR assumes that you can tell if you're in low or high without an idiot light!
An intriguing question I have posed before though is given that there is no transducer on the main gearbox to tell the ECM which gear you have selected, how does the ECM know to engage idle jack in the low range gears to which it applies (only 1st, 2nd, reverse IIRC)? Clever, eh!
Post #407198 13th Mar 2015 10:47am
jst
idle jack is 1st low. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #407200 13th Mar 2015 10:49am
Idle jack is not only 1st low.
Certainly 1st low, also reverse low, and I think 2nd low.
Post #407244 13th Mar 2015 1:22pm
jst
confirmed it, its 1st and rev Low. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #407286 13th Mar 2015 3:05pm
lohr500
Hi Blackwolf,
I think the idle jack is initiated through a combination of the low range gearbox sensor and either ABS speed or speedo sensors. If you pop the vehicle into low range on a slope and leave the main box in neutral then roll forward slowly the revs rise. Roll too quickly and the revs drop back to normal idle speed. Try the same thing in high range and no increase in revs Smile
Post #407465 14th Mar 2015 11:25am
