![]() | Home > Wheels & Tyres > Heavy Duty Steel Wheels (Wolf) |
Interesting detail shggdg
![]() Now, below are two pictures with detail of the HD Wolf wheels on the Heritage at the car show here. This one obviously has the latest uptodatest VIN, so must be using the 39mm long RUF500010 studs. In the pictures you can clearly see that all nuts go well over the end of the studs, with the studs ends sticking out a few mm. As a third picture I have added one of my own original LR Wolf HD wheels which are sold here as an official LR accessory winter wheel/tire package. The SVX VIN starts with 9Axxxxxx, so should be using the very same RUF500010 studs. But in my case the studs do not protrude thru the edge of the nuts, but are a few mm short of that, even if all thread is being used, so surely it is ok. Just curious where this estimated 4 mm difference comes from? Could the latest nuts used by LR be slightly different? Doesn't look like it from the pictures, but can not think of anything else. Eric Heritage ![]() Click image to enlarge ![]() Click image to enlarge SVX ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Prices do seem to be all over the place. LR Direct are quoting 3 sources with prices at £4.10, £7.75 & £89.90 ! http://www.lrdirect.com/FRC7577-Wheel-Stud...tAod8E0AkA |
Not clear but would you not suspect the £89:90 would be for a complete set perhaps? I would at that price.
![]() Treat every day as if it is your last....one day you will be right!! |
I clicked the link through to see if the photo or description changed to show a full set but it didn't; so I'm not sure one way or the other. Sadly, I don't think any of us could rule out LR charging this per stud.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17595 ![]() ![]() ![]() |
Landrover's standard multiple for this part is a pack of 5, and the FRC7577 part is such a pack.
So £89.90 should get you 5 genuine studs, ie one hub. So £359.60 for the whole vehicle. Bargain! ![]() Note that the Bearmach and the <censored> parts seem to be for a single stud only, so the price comparison has an element of the old chalk and cheese thing going. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
blackwolf is spot on, just ran the numbers through the system.
![]() Oddly the OEM ones are cheaper but i would hazard a guess they come from the same supplier anyway. |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
Whats the best tyres for them?
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
...... and almost 9 months later ........... I'm still very happy to have followed Keith's thinking. Sometimes it feels good to follow in the footsteps of others. Now roll-on Winter and I want some serious snow to play in. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2227 ![]() ![]() |
WOW ! I Thought this thread had gone .im greatfull for the following
![]() Keith Ps Don't forget your stainless nuts , and where are your finished pics ? Winters not far away mate |
These ones ![]() ![]() Click image to enlarge |
Dave k Member Since: 29 Feb 2012 Location: Cheshire Posts: 151 ![]() ![]() |
I can agree with that!
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Never Raced or Rallyed |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
If anyone is looking for a set, I've just spotted some genuine Land Rover ones on Gumtree:
https://www.gumtree.com/p/wheel-rims-tyres...1132981283 Nothing to do with me, but I thought they might be of use to someone. |
Rather than starting a new topic again, building on this one here.
It is about time to put the winter wheels/tires on again, so that means the HD Wolfs are coming out of hiding. Question is what are the correct torque settings for the steel nuts on these genuine HD Wolf wheels? Is it as high as 170 Nm I vaguely think to remember? The original nuts on alloys like Dual Tone or Sawtooths need to be tightened to 130 Nm, so can someone confirm that the steels need 40 Nm more? Tks, Eric Edited from lbs/ft to Nm You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
According to the official Defender Manual wheel nuts should be tightened to the following settings - 6.5" Steel Wheels - 170 Nm (125 lb.ft) - which is a lot more than the standard 5.5" wheels but the same setting as the 7" alloys!
Hope you are not driving around with your wheel nuts on your alloys only 'finger tight'? |
